K Koy Member Joined 2001 koy.hi-end.org 2002-01-30 8:05 am #1 2002-01-30 8:05 am #1 Does anybody know why Alpehœ have such relativelly low gain? wuffwaff Member Joined 2001 2002-01-30 11:55 am #2 2002-01-30 11:55 am #2 Hi Koy, 26dB unbalanced isn´t that low and 20dB balanced should also be enough. The advantage is that you can open up your preamps volume control a bit more wich (if it´s not a stepped attenuator) definitely improves channel balance. william Status Not open for further replies.
