Does anybody know why Alpehœ have such relativelly low gain?
K Koy Member Joined 2001 koy.hi-end.org 2002-01-30 8:05 am #1 2002-01-30 8:05 am #1 Does anybody know why Alpehœ have such relativelly low gain? ••• More options Share wuffwaff Member Joined 2001 2002-01-30 11:55 am #2 2002-01-30 11:55 am #2 Hi Koy, 26dB unbalanced isn´t that low and 20dB balanced should also be enough. The advantage is that you can open up your preamps volume control a bit more wich (if it´s not a stepped attenuator) definitely improves channel balance. william ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
