Heat Sinks
I have the P Daniel a30 pcb's as well. Parts Express may be a source for a transformer. To me the biggest issue is the heatsink. I was wondering if 2 extrusions 12"x5.375, .375 thick base plate with 1" tall fins would be enough cooling? They are available on ebay. I could also set up a computer fan for extra airflow.Any opinions on this?
maybe this is of interest to us Pass amp fans. found it while digging thru ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280076820327&ssPageName=MERC_VIC_RUPX_RUPX_Pr4_PcY_BIN_Stores_IT&refitem=280074032679&itemcount=4&refwidgetloc=closed_view_item&usedrule1=UpSell_LogicX&refwidgettype=cross_promot_widget
i have know idea if this would help in building a A30, but it is a heap of sinks!
I picked up a six of these heatsinks from BGMicro. Their shipping is kinda high, but the price for the sinks makes it an ok deal.
I can't decide if I need to use two or three of them per channel.
Use all of them! You probably allready heard that an Aleph 30 needs heatsinking? Think again, it needs a lot of heatsinking!! Just connect those fets, though leads and spread the heat as good as you possibly can!I can't decide if I need to use two or three of them per channel.
Steen
BTW the broccoli needs water
I just recieved my parts from
http://www.tech-diy.com/hexfets.htm
matched triplets of IRFP240's and pairs of IRF9610's
A note is in order. That site lists IRFP9610's. I corresponded to ask about that. They are IRF9610's. I'm sure there will be a change to the site when he gets around to it.
If you want to combine several items into one shipment it probably would be of benefit to send a note about that also.
The parts arrived in rails and anti-static bags. A good source.
Pathmark, looks like you will have good heatsinking, I have not yet bought any parts!
I think the thickness of the heatsink base plate is important, a thicker plate will spread the heat better and avoid local hot spots.Still looking at ebay.
Ed says
I assume the triplets will be close enough that 12 matched irfp240's are not necessary?
Ed says
of Irfp240'smatched triplets
Fellas,
I also had good luck with tech-diy. I bought enough parts for 4 boards and everything is matched nicely. thanks for doing your homework ed.
I received heatsinks yesterday and they look great, thick base but as everyone keeps mentioning I am still worried about the heat.
Pathmark
Pathmark
JFTR,
the heatsinks Bugg got for his Aleph/30 are not only great, but so cheap that i'm too damn jealous to be nice.
Even by the 6 in a cheap USPS Mondiale box, they'd cost me an additional $15/pc in mailing and dot-dot-dot taxes to buy them myself.
Bugg can expect 0.35 C/W at the least from a single one of his heatsinks, possible even a lot less if it's an efficient design. I hate you, Bugg.
According to Rod Elliott's heatsink calculator spreadsheet they should do .39C/W. With only 2 fets on each one I would think this thing might almost be kid safe. I couldn't imagine finding anything this size for so cheap. They are used but the ones I got don't have any obvious scratches.
Don't worry Jacco my broccoli hates you too
~michael.
~michael.
I hate you, Bugg
That's just a way to ask for your best cookie recipe... which I'm sure will be "terrible"
triplets will be close enough (?)
They are sold as triplets. In 12 samples the low value was 4.60, the high value was 4.63.....0.03/4.60... Less than a percent
I think the weak link in my system will be somewhere else.
Thanks Ed, I also will order those same parts
steenoe says
This would be a good way to spread the heat but will there be any performance change, perhaps speed and are additional parts needed to do this?
Digikey has the 3 watt panasonic .47r, part # is: PO.47W-3BK-ND, the no. will not work as a parts search, search this way in the parts window: panasonic .47, then scroll down to metal oxide[6] and you will find them .51 each or 5 for 2.38. At a certain order size, shipping is included[last time I did this]
steenoe says
just connect those fets, through leads
Maybe it's a Canadian thing. I order from DigiKey all the time (every other week or so) and have never had shipping included. (Not small orders either)
jacco vermeulen said:JFTR,
hehe
look at these.......each capable of coolin' ~50W with 25 Celsius rise above room temp.......
on pic-middle row,most right-you see two white marks ....of 50W Golden Dales ,used for measuring;
I have 4 more ,not on pic,slightly taller........
these 14 + 4 cost me 90 bloody Euros at junkyard.........they even lowered Al prices later........I hate them!
- Aleph 30 parts for Peter Daniel's boards
