Aksa Lender P-mos Hybrid Aleph (ALPHA) Class A Amp GB
ALPHA 52W BB GB interest list
Please edit and add your name and quantity desired and ceramic TO264 insulators if needed below. I will need at least 10 people to show interest before ordering.
Cost will be $60/pair (keep in mind they are beautifully designed big 240mm x 130mm, 2mm thick FRP with double-thick copper and ENIG finish). Shipping cost for a pair of boards in the US will be $8, Canada $17, and everywhere else is $24. Yes it high due to weight of the boards coming in at 10oz for the package. TO-264 ceramic insulator pads are $2/set of 4.
pelayostyle - 1 set
pcgab - 1 set bb, 2 sets TO-264 insulator pads
vvs07 - 2 sets bb, 4 sets TO-264 insulator pads
emynet - 1 sets bb, 2 sets TO-264 insulator pads
I have to confess not seeing/knowing how to edit and post alongside the others wanting PCB
I would like to be added to the list.
drpro BB 1 set, 2 sets TO-264 insulator pads
David
Alpha B.B. GB list:
pelayostyle - 1 set
DrPro - 1 set bb, 2 sets TO-264 insulator pads
wtl - 1 set bb, 2 sets TO-264 insulator pads
yoaudio - 1 set bb, 2 sets TO-264 insulator pads
Alpha B.B. GB list:
pelayostyle - 1 set
markus22ch - 1 set bb, 2 sets TO-264 insulator pads
Alpha B.B. GB list
pelayostyle - 1 set
*vvs07 - 3sets bb, 6 sets TO-264 insulator pads
I was just testing the Alpha BB this morning to check for oscillations at 5Mhz as suggested by Keantoken as a possibility. No evidence of it, here is 39vpp into 8ohms and then zoomed into and around 20ns/DIV:
675316d1523801913-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-5mhz-osc-study-jpg
675317d1523801913-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-5mhz-osc-study-20ns-timebase-jpg
ALPHA BB GB update:
pelayostyle - 1 set
Cambe - 1 set, 1 set of TO-264 insulator pads
Schematic:
attachment.php
PCB Placement:
attachment.php
BOM is here.
Hi X,
Just confirming that I received my boards and ceramic pads.
Definitely sweet looking boards!
Thanks for organising the GB!
PS - Thought I'd add some paraphernalia from the Commonwealth Games that my home city just hosted as the title seemed fitting 🙂
pelayostyle - 1 set
ekidnah09 - 1 set bb, 1 set of TO-264 insulator pads
I am seeing 36vdc for the supply, though I haven't been following the 20w version build closely, I believe a transformer plus CRC type supply is needed here. Will a 25vdc xformer make it or is perhaps a 28vdc a better choice.\
