Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Offset is completely safe up to +/-100mV. The goal is to get it within +/-30mV.
The benefit of a LTP is that both active devices, situated in one spot, share the same thermal environment.
As I mentioned, an offset within +/-30mV is bagatelle. A voice coil is unaffected by this offset.
All LTP transistor work under this regime. This one is actually a little tighter than most because of the unusual quasi current mirror at the collectors.
Hugh
I know that this is a newbie question, but where are the test points for the offset? Is it the positive and negative speaker outputs and the adjustment via R105?
If you drop supplies to +/-18v and boost current to 2.7amps that might drive 4ohms speaker nicely. I will confirm with a simulation. Will need to switch to IXYS outputs though for the 50w dissipation per channel. Still reasonable use same CPU cooler heatsinks or larger passive radiator.
Edit: The sims show that it can work well into 3.6ohm load at +18v and -20v (asymmetric rails) and 2.8amps for about 48w and 55w dissipation on the two MOSFETs. Set R131 to 0.22R and R132 to 0.1R. Pretty good low distortion performance out to 21wrms for even 3.6ohm load.
I think I'll go for the lower voltage version since my speakers don't need much voltage but rather some current.
Some ideas:
to get asymmetric rails I could use a regular transformer with symmetric outputs, but only add on the positive rail a Juma capacitance multiplier.
That will drop the positive rail with 2v.
For mosfets something from Ixys like the 40p50p 40n30p in TO264 package.
Those are also used in Pass XA25 but in SOT227.
Other suggestions ?
Are there any reliable spice models for those new mosfets ?
So far I've used the cordell spice lib in ltspice.
Regards,
Danny
Yes, you do not use the variable resistor, it's not a particularly good idea. Specify the current you want and then set the resistor on the basis of 0.62/Is. I suggested 0.27R for 2.3A, plus or minus a few percent according to the sense transistor's Vbe which I'm assuming around 0.62V.
Danny, I have attached my latest of the low voltage version set up for high current/low impedance drive. (Ignore some of the text I have put in for the 8R instance). The negative and positive clip is more six volts off rail, around -11.2V and +11.64, but this would improve considerably with high power high transconductance mosfets, which do not require so much Vgs to push through high current. I would not suggest using asymmetric rails; the power output into 3R at -11.1V and +11.1V, just below clip, is 20.5W, into 4R it's -11.4V and +15.0V, just below clip and a lower 15.4W. In either case the distortion figures are very good, typically 0.05% with H2 -69dB and H3 -72dB. Note that in these cases the third harmonic comes up and even exceeds the second at full output; this is a function of low transconductance devices in the output stage and I'd strongly suggest using the Fairchild or IXYS devices rated at 480W here since the increase of Vgs and high current is minimised compared to the IRFs products.
Hugh
xrk971,
I will do that.
Hugh,
I do not have your level of knowledge, so I’m not tracking. Are you saying I should make another change? Where would that be?
Brad
Thanks X,
You are 100% correct here. I think on reflection that the stage current should be set at with 3k3, then 6k8, then 1k as you suggest. If you are shy about 137R, the correct figure, the change in the offset is only about 3mV down, which is trivial.
Put another way, with a setting of 3k3/6.8k/1k, we have an offset of -3.35mV.
Set at 3k3/6.8k/1k2, the offset is +1.52mV, 200R leads to about 4.87mV, around 100R gives 2.4mV.
In truth, even for a Lowther an offset of up to 25mV is not important. It won't damage the voice coil, it won't change the sound, but it should be thermally stable, and this is where the LTP and Lender drive with diode pays dividends.
Hugh
It’s pretty mild and slow (0.2 second long slow motion) . If you have a high pass filter it’s fine. Of course if running direct drive active system then you may need delay delay. Also, if you are running a cap Mx, it has soft start ramp up voltage feature so I don’t think there is thump.
I have capMx but there is a small thumb, actually it's not thumb but same kinda cone movement that Vunce has also. Don't want to risk breaking 2" driver though, since I drive it through DSP without passive filtering.
When using a DSP, it is always good practice to add a capacitor in series with your tweeter, even if your amp has no turn on and turn off transients.
Hugh
Hi Hugh,
Thanks for the high current/low impedance simulation !
Very nice that you also got low distortion for 3r and 4r,
this will be lower with the typical output of -2v+2v that I only need to play already loud (94dbc)
I'll definitely use Fairchild or IXYS devices rated at 480W.
In my current F5 I also use Fairchilds.
Regards,
Danny
