Hello! Thank you very much! Sorry if I made / make technical mistakes - I'm not that good at it! Can you please write how can I wire the switches directly to the outputs? Kind regards!Old thread but triggered by a romanian post: as usual look up the type of the relay used and check if it has gold/gold plated contacts. When so (very often in older Japanese stuff) then replace for a sealed hard silver (bifurcated) contact version.
Speaker A/B/A+B switches are often a source for issues. It is best to just wire directly to the outputs.
Ah my romanian is somewhat rusty so I misunderstood. First measure power supply voltages and DC offset at the outputs.
Mult noroc!
Mult noroc!
Hello! Thank you very much! No problem! I forgot to write that the amplifier LED's was lit up - maybe this it's important. I have some knowledge about electronics but can you write me please how can I measure power supply voltages and what values of it I must achieve? For DC offset at the outputs I use a digital multimeter and the + of multimeter I connect it to + of speaker and - of multimeter I connect it to - of speaker, no? Kind regards!Ah my romanian is somewhat rusty so I misunderstood. First measure power supply voltages and DC offset at the outputs.
Mult noroc!
