Sure, and that is not a real problem from the standpoint of circuit design. On the other hand I am quite surprised how well the recent circuit sounds that I build with a single supply and coupling caps at input and output. Maybe the spectrum with dominant second Is an advantage or the inherent simplicity.
Read this and you will be astounded....
That's a very nice article Joachim! I gets really interesting after the line where you cut it off ;-)
Distortion Isolation in the Time Domain.
Jan
I have not read the entire paper, but it appears they are testing within a circuit rather than in isolation.
The only thing you can test in isolation is mass and dimensions.... Of course things are tested in circuit! Datasheets are often full of test circuits to document the test methodology (more commonly for chips than passives, but you can see the test equipment is identified in many datasheets (the good ones?). And guess what, a piece of test equipment is a circuit (!)
- Design & Build
- Parts
- AES: Evaluating Electrolytic Capacitors Specified for Audio Use
