I've been experimenting with curved plywood in an effort to build cabinets for my Tang Band W8-1772's ("Curvy Tangs"....haha ).
The goal is to end up with a 45L BR cabinet tuned to 45Hz or so. These cabs will end up on tubular stands with the port and binding posts on the bottom of the cabs.
So far I've tried 3/8" wiggle wood, which didn't work because un-kerfed it will not bend tight enough, and after kerfing halfway thru at 1/2" spacing, it cracked since the grain runs parallel to the bend.
Similar results with kerfing 3/4" MDF. I cut almost all the way through every 1/4" with an 1/8" width blade, and the board broke apart when making the tight rear bend. 18mm baltic birch took a couple of attempts; the trick is to kerf down to the last lam, and make sure the last lam grain is running perpendicular to the bend.
The two strips on the flat face are fixturing to keep the formers aligned in the same plane when wrapping and gluing the sheet around the sides.
The formers were fabbed by printing a full size paper template, then carefully jig-sawing out the first one, and using it as a template to make additional formers with a router and laminate trimmer bit. They are also 18 mm BB.
Next step is to laminate 1/8" poplar bending plywood on both faces (inside & outside) of the curved skin and then trim everything, including cutting the ends of the curved panel flush with the front baffle (which may be a bit of a challenge).
boywonder very cool project.
I'd skip the kerfed wood and use multiple layers of the bending ply. You could use formwood 2ply veneer for a nice outer skin.
Two-Ply Wood on Wood Veneer Stock List
The multiple layers of glue will make a very stiff final product.
Tight bond will work, But for the ultimate in glue I like
Vacuum Pressing Systems -- Veneer Glue
Its kind of nasty, and dries slowly, but will allow no creep when its dry.
good luck...Evan
good luck...Evan
Your cabinet shape is becoming popular. I have seen stacked laminate or translam construction, as well as frame+bended board similar to your efforts on several commercial speakers. The old school construction discusses steaming thin plywood sheets and laminating them together around a frame.
Some speakers attempt to reduce cabinet edge diffraction, reduce speaker side-cone reflections, and taper the rear to reduce standing waves and rear cone reflections.
White Light speakers use an airfoil shape cabinet front in a effort to reduce diffraction effects. The bluge in front provides some space between the speaker side cone and cabinet walls. The tapering reduces standing waves. I wish I had the cabinet skills to build an MLTL for my Tang Band W8-1808 shaped like the White Light cabinet. I was surprised how much cleaner the bass from the MLTL was over past wide-and-shallow bass reflex cabinets.
Hey, nice work! Are you putting a curvature on the front panel? That's where it's most critical for diffraction. I need to get down your way soonish.
Evan: Thanks for the links! I've been considering layering up 1/8" bending plywood if the heavily kerfed BB didn't work out. My hope with the kerfed 18mm BB is that I'll end up with zillions of little 7/8" tall I-beams once I glue the thin bending plywood to the inside surface. At least on paper, it should be lighter and stiffer (or at least as stiff hopefully, I haven't done any bending calcs) than one thickness of 18mm BB. With a layer of 1/8" ply on both the inside and outside surfaces, the walls will be 1" thick.
This is presently an experiment so who knows what I'll end up with.......
The present plan is for a two layer (1 1/2" thick) front baffle with 3/4" roundovers everywhere. The baffle will be flat where the driver mounts, as curving the whole front would be another level of complexity for my tiny brain.
Since this is an experiment, feel free to stop by and make some saw dust (and some router dust)...I'm game to do more curving.
Yes, you'll have to stop by and check out my latest setup; TubeLab 300B and Half Changs........Send me a PM and let me know your availability.
What advantages does the 2 ply veneer offer on curved surfaces compared to the conventional paper backed stuff?
sorry i'm slow getting back.
The 2 ply veneer doesn't transmit whats under it as much. and bends well without cracking.
the downsides are restriction in attainable radius ( i.e larger ), and more exposed edge core than with the paper back
The edges will be covered with solid ends and baffle....this experiment is continuing..had a few failures... but I'm slowly moving forward. I'll have more time to build these shortly.
I've been building some fixturing that will allow trimming the front edges on the tablesaw. The test piece shown is also twisted about 1/4' end to end, so I've make some fixturing for that also.
My present plan is to still use kerfed BB (1/2" presently), then contact cement 3 or 4 layers of 1/8" bending ply around the BB, then veneer.
I have a 4x8 sheet of paper backed quarter sawn cherry, so that will be first up once the design is up and tested.
I have a steam iron.
Bear: I'm a rank amateur who has the capability of making lots of sawdust and firewood........I think you'd need a steam engine to bend 18mm BB though...
I had high hopes for 3/8" wigglewood.....complete failure; it won't bend nearly tight enough.
I believe the pros who bend use steam...
_-_-bear
A couple sawhorses, some polyethylene area cover (as used in painting) and an electric teapot will do the job, with gravity.
Not so much with 18mm BB ply though, you'd have to go to smaller layers.
considered paper mache?
Actually as silly as that sounds it could work...but not "paper mache"😛. What i am thinking is several layers of thin card built up with glue. It should work.
The last cabinet shop I worked for did a lot of curved plywood construction. We almost always used layers of 1/8" ply, usually 6 layers, veneered inside and out. The resulting product is amazingly stiff, and springs back almost not at all when taken off the form. The wood on wood 2 ply veneer bends a tight radius and the edge does not show a black line. Anyway.... regardless of the exact materials you use if you do a careful job I'm sure you will get an excellent result.
As does our shop as well - the key to structural integrity would be to not use contact cement or white glue - (both are too flexible) but something that cures rigid like yellow carpenter's glue, the vacuum press material that Evan mentioned or a 2-part catalyzed adhesive.
Of course you're likely finding that the toughest part of the project is building sturdy form /frame upon which to laminate your layers of material.
Well, once the first layer is wrapped/glued around the formers it's there for life, so no spring-back to worry about.
I'd love to use yellow PVA glue for the layers of 1/8" bending ply but I don't know how I'd hold everything together without a vacuum bag, that's why contact cement is so appealing......
For tooling, I pretty much have what's shown in the pics; various clamps and straps.
I do have several vac pumps and vacuum regulators, so the bag approach is interesting, I just need a vac bag and some skill.
bags are not too expensive. But your form needs to be strong enough to not implode when you apply the vacuum.
[/B]Dura-Max? Vinyl Vacuum Bags: Simple & Affordable
For curved work the breather mesh works great to allow the air out that would otherwise be trapped by the bag where it touches the project. Trapped air stops the bag from pressing where the bubble is.
DIY Vacuum Bagging Parts - Build Your Own and Save
then definitely the unibond 800 as glue.
As far as skill goes you need a helper to get everything glued and in the bag. Then a dry run to make sure you got it and your good to go.
- Design & Build
- Construction Tips
- Adventures in Curved plywood.
