Add Best Diy Projector Here With Image For Inspiration
Here is a screen shot from my 17" vertical Pro-V projector.
Here you go:
17" samsung panel and controller
550/220mm fresnel split config
500mm FL triplet 100mm diameter
400w MH bulb BT28 style
magnetic ballast
2 120mm fans 112cfm ea
FS mirror
enclosure is 30" tall, 16" wide, 18" deep
its a folded vertical design with the optics tilted at 60 degrees to fit the FL of the optics, I use keystone correction of the field fresnel to get the image correct.
this is one of many designs I have built, do you want to see more of them?
Right now I am finishing up a horizontal folded model with a 10.6" panel in it.
