Found forum topic on exact same issue on another site. Here they suggest moving up to a 39,000uf 100V (125v surge) cap from mouser which is no longer stocked.
http://www.stevehoffman.tv/forums/showthread.php?t=38831&page=2
You can probably get away comfortably with a 75V cap and still have plenty of headroom for mains surges. Mouser has a Vishay/Sprague cap here
~Brad
~Brad
Hi Brad,
No. The breakdown voltage is important. The difference is too great here.
Hi montfriz,
How old did you say that amp is? Of course they don't have stock. The replacements would be as old as the amp as the parts are bought at the same time. However, you can find something the same approximate size physically and the same voltage and install those The actual capacitance is not that important given the tolerances. You may need to change to some PC mount parts but there is always a way.
-Chris
Hi montfriz,
-Chris
Montfritz,
I have new and unused Adcom power caps they use in the 300w/pch GFA-5802. The 565 is also 300w/pch so they should work. They are the same width but slightly short so they will drop just right in the current slots... that is if you can settle with the being 22000uf 100v .
That being said, I have 2-3 565's lying around and I can take out the big caps you want and put the 22000uF's for my use... how much would the 35000uF/100v be worth to you? I am just seeing if they are worth my time to sell them to you and go with the 22000uF (which by the way Adcom sells for $62.5 each )
anatech said:Hi Brad,
Hi Chris,
Whats the voltage on the secondaries? It was my understanding that they were under 40V... If it is higher than that then please disregard my 75v cap suggestion.
~Brad
The rails on the 565 are around 82-84vdc per rail depending on Mains AC.
Chris... Can I use a 100v cap (125v surge) on 100v rails? i.e. will the surge rating take care of the 20% margin that you need to have typically? Please note: It is Very hard to get caps over 100v ratings incrementally... you need to go to 160v or 200v both which are either too big or less capacitance.
Hi Arif,
I am not comfortable with that. What if your average hydro voltage is boosted in a couple years? The life on the caps would be shortened for sure. How about some 65V units in series? I know, I would try to get around that as well but if it's the only way. Or find another brand using special order 125V caps and buy tho$e. 160V is not too bad except for the exponential pricing.
-Chris
-Chris
Adcom problem solved
Brad and Chris:
Thanks for the help ,contacted Tim on the other forum he gave me info on JEA Capacitors in New York phone #800-645-2666 they have the caps in stock and 2 are on the way to me in Cape Breton. They sell for $ 68.40 a can and are new.
Thanks again, Harold
Brad and Chris:
Hello MJR :
Well buddy are you sure we have the same problem??? Mine ultimately lead in another direction. I got two caps from www.[url]http://jeacaps.com/[/url] (great service) now they are paperweights on my desk. See my amp was misdiagnosed and the caps are fine it was the caps and transisters on the driver board that were the problemmmm one had leaked and........the amp is fine now....I can say I learned alot from that little LEAK... Take a peek at this site http://www.angelfire.com/art2/stereorepair117/adcom.htm it pretty well sums up the problems ....hope this helps, any further assistance just send an e-mail.
Cheers Harold
Cheers Harold
Hi Harold,
-Chris
Now that I can believe.See my amp was misdiagnosed and the caps are fine it was the caps and transisters on the driver board that were the problemmmm one had leaked and........the amp is fine now
-Chris
montfriz said:Hello MJR;
35000 MFD
100 VCD
+/- 20 % 85 degrees C
Cheers Harold
Hmm, I have looked through various capacitor manufacturers such as Cornell Dubilier and have never once seen a capacitor matching the exact values of the original ADCOM GFA-565 capacitors (35,000uF @ 100V {125V Surge}). I just pulled the capacitors out of my amp...one works and one is dead. I really want to replace both of the capacitors with brand new electrolytics at the same time. And I want 4 of them so I can replace the caps in BOTH my amps.
Does anybody see any problems with downsizing the capacitors? Could I use 100V 22,000uF capacitors instead of the 35,000uF ones? Or would that create a mismatch between the capacitors and the massive torroidal transformer's power requirements and create problems in the amp's circuitry and function?
Hi mjraudio,
-Chris
No, but high power level performance into low impedance loads may suffer. Look at it another way. Works much better than an open cap!Does anybody see any problems with downsizing the capacitors? Could I use 100V 22,000uF capacitors instead of the 35,000uF ones? Or would that create a mismatch between the capacitors and the massive torroidal transformer's power requirements and create problems in the amp's circuitry and function?
-Chris
@anatech: I respect your input at diyAudio forums as you are very knowledgeable and have helped many people with their amps. Thanks so much.
I'm going to order a pair of ADCOM 100V 22,000uF capacitors from JEA Capacitors on ebay, does this look alright to replace the GFA-565 100V 35,000uF capacitors? (I'm going to try repairing this broken one first before purchasing caps for the other, functioning amp).
http://cgi.ebay.com/2pcs-ADCOM-100v-22000uf-computer-grade-capacitors-NEW_W0QQitemZ200074177411QQihZ010QQcategoryZ36336QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hi MJR,
You might also consider the following if they'll fit:
http://www.apexjr.com/images/CAP68KMFD.JPG
http://www.apexjr.com/capacitorsR.html#Computer
I always like to try to improve the performance of the amp if possible when replacing parts.
Apogee said:Hi MJR,
Wow thanks for the link. That would be awesome, but it is labelled weird! It says 68,000 MFD 100V. I need at least 35,000uF...is that labelled as millifarads?
- Adcom 565 amplifier HELP
