anatech said:Hi Brad,
No. The breakdown voltage is important. The difference is too great here.
Now that I can believe.See my amp was misdiagnosed and the caps are fine it was the caps and transisters on the driver board that were the problemmmm one had leaked and........the amp is fine now
montfriz said:Hello MJR;
35000 MFD
100 VCD
+/- 20 % 85 degrees C
Cheers Harold
No, but high power level performance into low impedance loads may suffer. Look at it another way. Works much better than an open cap!Does anybody see any problems with downsizing the capacitors? Could I use 100V 22,000uF capacitors instead of the 35,000uF ones? Or would that create a mismatch between the capacitors and the massive torroidal transformer's power requirements and create problems in the amp's circuitry and function?
Apogee said:Hi MJR,
You might also consider the following if they'll fit:
http://www.apexjr.com/images/CAP68KMFD.JPG
http://www.apexjr.com/capacitorsR.html#Computer
I always like to try to improve the performance of the amp if possible when replacing parts.![]()
