Active crossover design?
Have a look at the sub-woofer controller and input buffer and high-pass filter projects on my website - use dual op-amps though. If you want more modularity and are stuck with single op-amps I have the pick-n-mix active crossover project (use the 2nd-order filters). I have a simple program on the utilities page of the website to calculate values for the filters.
is it a crossover you need or a pair of matched Low Pass and High Pass filters?
search for Ti.com
AAJ slyt306
Ti also have a large number of papers (application notes) on designing and building and correcting for errors of the various filter types.
Burr Brown also have software filter2 (S&K and MFB) and filter42 (state variable) that work well.
Try Linkwitz web site.
