its got those nice specs for home use
but also very expencive
do you know this woofer ?
No, it's more a combination of spec.s coupled with the particular diaphragm.
I really like the sound of similar diaphragms on drivers - i.e. honeycomb core with composite skins like Eton. Tends to provide a high degree of clarity WITH tone, which is an unusual combination. Of course it also results in a nasty break-up region that needs to be dealt with if coming anywhere close to those freq.s for operational bandwidth.
Here is another one with a slightly lower Qts and a bit more xmax:
15W930 - Extended LF Ferrite Driver
18 Sound 15W930 8ohm 15 500watt Extended LF Ferrite Loudspeaker : Lean Business, Outstanding Audio, Bass Guitar Speakers, Celestion Guitar Speakers, Guitar Amps, Tayden Guitar Speakers, Pro PA Speakers, Celstion spares, Celstion Vintage 30 and more!
BD BD15 are very good 15"s for home. Low Xmax but does it matter with a 15" midwoof in a home rig? Not too much. They have a very easy to manage top end, low inductance thanks to a light single layer (I believe) coil,
I dont see anything about demodulation rings in the PDF for that Precision Devices woofer. It looks like it has very smooth response, and I'm sure it will work very well. It also will not match the distortion performance of the AE woofer.
I would see what some of these woofers go for locally
B&C 15TBX100 15" Woofer 294-670
Ciare FXE15-4 - Ciare FXE15-4 is a powerful 15" speaker for all mid-bass and bass speaker systems- Ciare Speakers - Ciare FXE15-4 15" speaker has an aluminum demodulation ring for lower distortion. Ciare FXE15-4 15" speakers available now.
Faital Pro 15FH520 Speakers - Faital Pro 15FH520 bass guitar and PA speaker that has a lightweight neodymium magnet - Faital Pro 15FH520 1,200 watt high efficiency of 98dB SPL woofer for all high power mid-bass and bass applications. Faital Pro 15FH5
B&C 15 TBW100 is a 15" high power woofer for speaker subwoofer systems- B&C Speakers - B&C 15 TBW100 15" high power speaker for speaker subwoofer systems with a 12.0mm Xmax. B&C 15 TBW100 high power speakers available now.
130-160 gram moving mass 15" woofers seem to take a lot power to hear/wake-up - TD15M should be nice for some 2-ways
this was either a 15tbx40 or 15pzb40 compared to a JBL M151 - mic on ground - maybe the pzb due to HF extension. If I can stay alive then will use the pzb40 for some Econowaves. That 15FH520 looks like a good driver.
if money is a concern, then AE nor PD worth the expense for home usage. You are going to be using a small fraction of those woofers potential. If I needed 15in woofer for home use, I'd look no further than these MCM Audio Select 15'' Die Cast Woofer with Paper Cone and Cloth Surround - 200W RMS 8ohm | 55-2963 (552963) | MCM Audio Select
ScottG,
AE TD15H have 14mm xmax, you think this is "lack" ??
cheers
henry
No, 14mm is excellent, but dissimilar from most lower Qts drivers in that respect. Most others tend to range anywhere from 3mm's to 8mm's.
The AE driver is however quite a bit more expensive when you factor-in shipping and import taxes when compared to what the poster can get in GB (..at least from Celestion and 18 Sound). On the other hand it's probably not more than the cost of *2* less expensive drivers.
Though I've not mentioned it before, I can't recommend the AE drivers.. (promised a friend.. resulting from a few people that have experienced serious customer service problems on their orders. Hopefully any issues have been resolved since then, but apparently the ordeal was so off-putting that I was requested to refrain from any future recommendations.)
The lambda motor used in the Acoustic Elegance TD series is state-of-the-art technology in a relatively low cost package. It offers very low distortion, fine power handling and extended high end response. The company is a small specialized manufacturer that is at the mercy of a variety of parts suppliers. Some of these are overseas have proven unreliable resulting in significant availability issues in the past. Current lead times on most drivers range from 2 to 4 weeks according to the AE website forum. The TD-12S drivers ordered this summer for a project arrived 3 weeks later and measured very close to specification. The results were well worth the cost and wait.
FaitalPRO | LF Loudspeakers | 18FH510
single spider and 'smallish' 3" voice coil might make it well suited for hifi use
btw, a single spider gives it the lower Fs, and still with lowish mms
price is ok at 200GBP
How important are the demodulation rings in woofers, if the crossover point is sub 1000hz?
I know it makes Le more linear and reduces distortion, but how much of a difference is this going to make when compared to a well made unit without?
Usually not much.
It really needs to be measured as an HD sweep to get a good general impression of it's non-linear performance.
A larger driver will show rising distortion much lower in frequency then say a 6.5". I agree the measurements of all the drivers in question would be ideal.
The original question was about the AE15, which has a ton of copper in the motor...
If you're going to keep them more than 10 years or subject them to temp extremes like freezing, I'd avoid foam surrounds. I'm just fed up with foam surrounds and I'll never buy another speaker that has them.
I was looking for a low QTS woofer.
To cross to this compression driver (in a horn) anywhere between 500-1000hz.
Active EQ system to dial into room.
More detailed information == better answers.
"I want to build a speaker similar to the ??? "
"I plan to use a ??? compression driver in a ??? horn/waveguide"
"The maximum speaker box volume is ???, maximum height is ???"
"My room is ??? sq ft with ??? physical challenges"
"The best speaker room placement is ???"
"I want ??? db/watt SPL efficiency"
"I ?will/not? have extra room bass woofers"
"I want _this_type_ of controlled directivity"
etc...
e.g. A high quality 2-way typically demands high quality drivers.(Lynn Olson thread strategy)
e.g. A high quality 3-way migh allow a low cost woofer, or a modest cost horn/waveguide compression driver (econowave thread strategy)
p.s. I have used over 40 Lambda AE speakers. The M-models have sound + BW + efficiency that is difficult to find in any other brand.
how did a US guy dig that woofer up 😀
but you are right
interesting specs
though may be overpriced
could be because its an older woofer designed before the internet
- Acoustic Elegance - Worth the money?
