I bought this sub and center speaker from a thrift shop the other day, Ive just gone to set it up and Ive come across this weird input plug on it? I tried to find an owners manual download but all I found was a picture of the same model with the input and output arranged the other way around? So to make sure of this Im uploading some photos to see if anyone knows whats what? I thought it was an optical plug at first but on a closer look I could see it wasnt.
Looks like the metal shell has been pulled out. Go ahead and plug into the red jack and see if it works.
Yes Dan, I'm certain you're right, well spotted, I did initially wonder whether it was a jack as well
I tried an RCA plug on both the input and the output, nothing happened on the output and a hum was the only result from plugging in the RCA to the input. The female input jack isnt missing anything, thats the way it is because I checked out another image of this model Accusound OM650. Unless the image I Googled had the same problem?
I Believe You RCA's are swapped or The shell is broken.
If there is some sort of short in the connectors, the will be no output indeed.
Have You tried plugging in a music source or just the humming cable ?
Take a look at this picture.
Accusound OM-650 Subwoofer Plate Amp - Classifieds - Audio - StereoNET
Better still, this is what it should look like
https://i.ebayimg.com/00/s/MTYwMFgxMjAw/z/~2EAAOSwZlZaP4UW/$_35.PNG
It seems they get a lot of abuse 😀![]()
Its more likely **** weak soldering because Ive knocked RCA plugs out by walking through the cables before but they havent come completely out like this?
They are just pressed together, you can pull out the shell and move it to the other jack.
So I can pull one off another RCA jack and slip it onto this one? Wouldnt I have to clamp it on by pressing it to a metal earth?
You need something like this
10pcs New 2 RCA Female Pin Jack Audio Video AV Socket Connector s533 | eBay
The shell is the ground and should make proper contact internally. No wonder it hummed. I wouldn't be happy if this were mine. I'd have to replace the connectors.
regards
Graham
regards
Graham
Ill order that RCA bracket today but Ive got to get some sleep now its 4.34am. Thanks fellas youve been a big help! Otherwise I would probably be still scratching my head. lol
Because of "cheap" RCA connectors and for longevity purposes and because of possible damage I recommend rather than only pulling the plug just turn/rotate it additionally.
This will reduce the strain on the connector.
Also it doesn`t matter if you turn it clockwise or counterclockwise.
It should come off either way.
This is the only time Ive known this to happen to an RCA plug, well, mine and the same model subwoofer I Googled for comparison had the same problem? I think it mustve been just a bad batch from the factory because Accusound is a family owned Australian company who makes good gear, I couldnt imagine them scrimping to save a few cents on some RCA plug seconds? Anyway, Ive ordered those 10 RCA plugs and Ill just solder one in when they get here. Thanks again for the help fellas.😀
- Subwoofers
- Accusound Sub with strange input plug?
