Accuphase c200x
First : please correct your manual link, post 18.
We already knew that the line inputs are quiet.
Again : I do not understand your reply. This may
be a language problem and failure of automatic
translation. Please consider this when reading and
writing.
Noise may be what is called ruido in Spain ..
Phono inputs without turntable, volume
up and inputs shorted : hum or not ?
(I suppose that you know what shorted input
means, but not sure .. ).
Noise is not hum, but hum is sort of a noise.
This is why I asked for 50 or 100 Hz hum.
It appears that you are not able or not willing
to reply to precise questions which are aimed
at a systematic approach to troubleshooting.
Please let me know, otherwise help is not possible.
Miguelnoda-- the phono input in any amplifier is usually the most sensitive , it therefore stands to reason that it can pick up external noise not just internal noise generated in the amplifier .
That is the reason AS_Audio asked you to ---Spanish-- cortocircuitado the phono INPUT , I am not a Spanish speaker only some French & German so I don't know if that is the right word .
Until you do that its hard to make progress with your fault.
4559DR (Texas Instruments ) is currently available as a direct replacement .
Of course you could "upgrade " it to some fancy audio IC but your circuit is designed for this unity gain BW of 3MHz upping this without any change in compensation --might work but there is a good chance of HF oscillation .
