Accelerometer Testing of Loudspeaker Drivers
I received a new batch of PCBs and Front Panels for the AP-2, the new version of the ACH-01 accelerometer amplifier.
I also provide detailed documentation to build the amplifier.
If someone is interested, send me a message.
I have a few questions:
1. What is the BOM cost for stuffing the board?
2. Do you have a Mouser, Digikey… BOM available?
3. The front panel is made for which enclosure model?
1. The cost is about 95 Euros, except the PCB, the Front Panel and the ACH-01. I made this cost estimation about a year ago.
2. Yes, with the order of PCB and Front Panel, I include a Parts list with component order codes from Farnel and Mouser.
3. The front panel is for a Hammond 1590 aluminum box
According to TE Conectivity (the manufacturing company), the ACH-01-04 with 12" wires is active but out of stock at the moment.
This happened also several times in the past.
So if you cannot find it second hand, I believe it will be available soon.
PN is 805m1-0200 (200g). Searching « te 805m1-0200 newark » from Google should make it the top result. Unfortunately they are « Not currently stocked » (maybe the reason for the sale). There is currently one ACH-01-04/10 (the one with unterminated wires that George was referring to above) on eBay at 39.99usd from seller « wolfborg1 ». I don’t know what was the MSRP for these but looking at comparably spec’ed alternatives from TE (such as 805M1’s) that seems reasonable.
The ACH-01-04/10 is the same as ACH-01-03.
The only diffrence is that the ACH-01-03 has a very convenient connector and a shielded cable,
while the ACH-01-04/10 has three 12" wires and no connector.
regards
George
ACH-01 accelerometer seems to be out of production now. I am looking for other sensors that could be used with my amplifer.
A good alternative, with also a nice price, is the "584-eval-ADXL1005Z" from Mouser.
It is a very small Evaluation Board for the ADXL1005 Analog Devices chip.
Another possibility is the 805M1-0200 sensor from Measurement Specialties.
Both have analog outputs and need some cabling for connection to the amplifier.
Your comments on the above sensors or any other proposals are welcome.
