A30 - Finally!
gema said:
marble legs
Touché. :clown:
Still the cleanest home-brew Aleph from every angle i've yet encountered, but judging from the drill marks you don't seem to be novice mechanical material.
The PS sub-chassis and vented back panel are real eye catchers, shame there's not a picture of the mounted PS sub-chassis in the bunch, but No Spaghetti beats any fancy stone.
Hi Gema,
Congratulations! Very nice work.
I am jealous.😉
I would like to mention two points:
make sure the Faston connectors are very tight on the rectifier lugs.
If loose, the resistance increases and that will lead to a hot spot/connection. I experienced that in one of my amps. I then soldered the wires straight to the rectifier lugs.
Power resistors should be mounted above the pcb. A gap between 0.25 and 0.5 inch (5-10mm) helps the cooling and will prevent damage to the pcb if the resistor gets very hot. Burnt pcb smells foul. Burnt pcb also becomes porous and moisture can create a path between tracks and pads and create havoc with signals and power supplies.
Enjoy your amp.
Serge
Maybe this little thing will help someone.
I don’t like trimmers of any kind, so in this project I came across a solution for fitting resistors that may be easily swapped with resistors with different values. The catch is in the pins taken from DIL IC sockets.
