mudakas said:Hi everyone,
Finally my boxes are painted. Prep+sanding+primer+sealer+2 coats black+4coats lacquer -
all done in a amateur body shop garage. Any hope to achieve black piano finish? I am so afraid to go with sandpaper or rubbing compound over the present finish...
It's tough to hit it with sandpaper when you have a decent gloss, but sand you must if you want a super high gloss like Shin showed. Be sure to use a stiff sanding block and clean thoroughly between grits.
Hey, good info guys!
I sprayed my car with transparent coating (pontiac lemans in red....) and had a few problems in the beginning (wrong substance paint to start with, can said quality this...quality that.....UV protection....outdoor use.....2two days later I polished it off like an orange peel actually....)
I finally used 'aircrafts' spray paint and can even re-do a small part of the car this way and sand-polish all the spray edges and orangepeel effects away afterwards leaving no traces whatsoever, just clear shine...(can spot something between my teeth in the reflection...)
Can post a pic of the paint container if anyone's interested....
I use plenty of water (add a lot of times...) and sand it with my hand (no block)....Don't be afraid, don't paint in thick layers (just arays of small drops....every couple of minutes....) and move in circles.....
jackinnj said:I wouldn't "hit a dog in the derriere" with a Wagner sprayer. Invest in a decent compressor and HVLP sprayer -- will save a lot of grief.
I don't know which Wagner is being referred to, but this one is a favorite among hobby types and small woodworking shops..
http://www.gleempaint.com/hvcongunnew.html
If, OTOH, we're talking about the "Whirlybird" or the "Buzz-blower" types, then yes, I wouldn't bother with them.
Best Regards,
TerryO
I understand the part with sandpaper #2000. But after that how to get back gloss? I am trying on a bottom part with rubbing compound and what I get is lots of swirl marks ... I am doing it by hand using auto polishing cloth.
Many automotive rubbing compounds will get rid of scratches as coarse as 1200 grit (meaning they are around 1500 to 1800 grit). You probably need to go to a finer polish. One of the 1200 grit compounds will mess up a 2000 grit sanding job, as would a coarser paper.
It's a tedious job at any rate - renting a polisher would probably be a good idea. Be sure it's a powerful one - not one of those $30 buffer/waxers sold for cars (they are fine for touch up, but won't get you anywhere when polishing) Get a couple of heads, use one for each grade.
Be careful to buff so that the head spins from the box then off the edges or you will burn through the paint easily.
BobEllis said:Many automotive rubbing compounds will get rid of scratches as coarse as 1200 grit (meaning they are around 1500 to 1800 grit). You probably need to go to a finer polish. One of the 1200 grit compounds will mess up a 2000 grit sanding job, as would a coarser paper.
That explains why it doesn't want to shine on me using one man hand polishing
I'm sure these methods will work on guitars? For someone who has never painted anything without a roller
what sort of base coat paints are we talking about? automotive? So the shine really comes from the clear coats, not so much the paint itself?
I knew a guy who cleaned his gun with gasoline after painting his house... the outcome was not too good! flames and melted plastic were the result!
jackinnj said:I had a Wagner -- they are OK to spray latex on the house or on a fence, but (in my opinion) aren't up to the task of dealing with a lacquer. I would conjecture that they might be dangerous with something which uses a volatile organic solvent.
NO1B4ME said:I bought the gun suggested from spraygundepot.com and need help. I also own a Sears 60 gallon compressor.
Where can i buy paint locally in the US. I tried Sherwin williams and they quoted me 250.00....
Try getting an auto repair shop to purchase your materials --
not sure it it has been said but i have used say Lacquer on the finnish
yet i still manage to chip the paint work / scratches off easy/ to those that i make not brought stuff
so basically any way to make sure the paint is not so easy to come off.
thanks and some good tips there![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Dryseals said:
If you are using cans, ignore anything I wrote. I would never try to achieve that kind of finish with cans, far, far, far too much work.
I like to use automotive paints, here in the US we can pick them up for a reasonable price. This requires the use of a compressor and a gun, but the amount of work to achieve the same finish is a fraction of what you are doing.
I'm working on several sets of speakers now, The ones for the shop I think I will paint black and post the results with just the single stage black, no sanding and no clear. They will not be as perfect as yours, but it may give folks like me, too lazy to do all that work, something to shoot for.
I am all for least amount of work with good results, thanks for posting.
gychang
If you have special lack which has already pain in it, so then just use it. Othervise use paint and then lack.
I have such thing to ask:
-What do yoy guys prefer Random Orbit Sander or Palm Sander. Quality difference or smth.
Second thin is- should I get also Polisher or use hand and cloth?!
rinx said:I have such thing to ask:
Since I posted this quick guide I've further improved my own technique and now can get even flatter and more mirror like finishes:
Compare these shots to the ones on the first page and even with the camera its easy to see the difference.
To achieve this I use a small 1/4 sheet palm sander, as before, for the bulk of the flatting out. But once I've got a completely matt sanded surface I'll then move onto a stiff rubber sanding block from 3M and proceed wet sand by very carefully drawing it across the work in horizontal sweeps alternating with vertical ones. I do this about 5 times. This really does give that last ounce of flat surface uniformity to the reflection that makes a difference. Just be extra careful to not dig in with block or apply too much pressure, all you need to be doing with the block is drawing it across with the weight of your arms alone on it.
I used to do everything by hand because the buffers were quite scary after I ended up trashing a paint job on my first go. However with care they are absolutely invaluable. I would never hand buff the cutting compound stage again. To give you an idea of how worthwhile these are, that cabinet shown in the photo's above would take around 2-3 hours of hard graft by hand, the buffer does it in about 40 minutes with little effort.
Remember when your buffing by machine to keep a handy spray bottle filled with water nearby and occasionally give the buffing pad a couple of squirts to help breakdown the cutting compound.
Always do the final wax/polish by hand if possible. Finesse at this stage really shows in the final gloss. Its like those guys who do the showcars, they never use a machine buffer on their high gloss custom paint jobs.
That's a marvelous finish, I must say. At first, when studying the first picture, I began examining it closely, and noted the fact that the gutter, window frame, and sun room frame, of the house next door were not straight. My first thought was a poorly performing camera lense, or some other malfunction.
But reading further, I can clearly see that the picture was taken as a reflection from the surface of the furniture.
Anyway, congratulations on a job well done.
Im having a problem with my finish and am in need of some ideas..
the problem im having is with the lacquer coat,
i started with bullseye sanding sealer then sprayed sherwin williams oil based primer and paint(hand full of coats each). I primed, let dry for 24 hours then the gloss black. waited 48 hours to start the gloss.
I went with minwax brushing lacquer to give it a try..
the first coat ate through the paint and primer, crinkled up, but only in some spots and mostly on one speaker and stand while the other was fine?
I thought i must have over applied so i stripped back to mdf and repainted. started with minwax lacquer in a spray can to give it a base/protective coat. went on fine. moved on to the brush very lightly applying a coat....same ****????cracking and bubbling. its not global just in select areas? could it be a lack of primer??
the other stand i was able to apply lots of lacquer with no problem.
any ideas?
any ideas?
- Design & Build
- Construction Tips
- A 'how to' for High Gloss Finishing
