Has anyone tried using regular kitchen plastic wrap for a membrane? I'm just looking for a pure diaphragm material - will be adding the traces separately.
Also, what Tesla strength is considered sufficient? The design I'm working on gives ~0.2T across the membrane in Femm.
Thanks in advance!
Thanks in advance!
diaphragm material
I stopped using plastic diaphragm material too much trouble stretching, the material I use now is just stuck straight on,and works perfectly for me.
sure, saran wrap. Do a search here, there’s lots of banter about that.Has anyone tried using regular kitchen plastic wrap for a membrane? I'm just looking for a pure diaphragm material - will be adding the traces separately.
Thanks in advance!
paper that pictures are printed on, any picture can be used for the diaphragm, family art monsters you can chose what you like. This picture is my latest design!https://www.diyaudio.com/forums/attachment.php?attachmentid=927106&stc=1&d=1614518756
Of course, why not. That never occurred to me. Interesting. But paper would be more fragile, no? Also because it won't stretch it must also be vulnerable at high spl?
- Planars & Exotics
- A couple of planar questions
