900W H-class PA Amp with Limiter
depends on how loud he plays his music, the situation is not that dim, only that the amp may never clip before the mechanical limits of the speakers are exceeded....
lowering the rails by 40% halves the power, a rough guide if you want a lower rating for the amps....
hi guys..
i'm planning to build an h900 base on apex. but the only thing is my transformer reaches +-75v and +-150v. i'm using toroidal transformer and since it is permanently made, i don't have a chance to reduce my rails. Is there any revision on vas and biasing on h900?..
happy holiday everyone!!!
Hi..Engel..no..no...new pattern..H900tef used original layout H900. Like this:
can somebody share tripple ef lay out
hopefully 7 pairs or up
hopefully like SOERDJANTO pcb,''BUT FOR SHARE,NOT FOR SALE''
IRVYNJAY lay out of step can be use for lay out like soerdjanto and chestap style of output layout and also vertex lay out,i see this output lay out advantage of consuming space to prevent long heat sink,
