900W H-class PA Amp with Limiter
bias settings
dear chestap
i am a new diyer on this forum decided to make both your amps i have tested step and dc protect on your pcb both working can you tell how to bias amp and please procedure
warm regards
dilip kumar
THANKS
hi Chester
greetings first of all THANK for giving diyers another H class amplifier
SUPERB SOUND QUALITY and the assistance you have provided all the way i am really grateful for schematic and great pcb design real good bass crisp highs and
POWER
1 any diyer making this amp please cut nc no connections on pcb of relay otherwise no problem amp came on first time once again thank you chester looking forward to make more amps of yours
warm regards
andrew lebon
pcb
hi ravpreet
greetings there is no PCB for vertex at the moment
nobody is sure if vertex schematic is ok so why waste your time and money when you are not sure if its going to work why dont you make both h class amps on this h900 thread both amps are tested for sound quality and reliability
warm regards
andrew lebon
Chestap amp succesfully build and tested
effort pays off
test only on 0/45/75 -/+vdc power is good even in low voltage
i have no regret building this amp many thank's to chestap
