nice work sir..
very nice work sir can u pls post schematic ...
thank u ...
hello sir...
thank u ...
bias
hi chestap
greetings whats the bias voltage over emitter resistances and
bias prest 3k on driver pcb NICE WORK whats the power in 7 pairs
warm regards
andrew lebon
hi chestap
warm regards
andrew lebon
CONNECTIONS
HI CHESTAP
greetings can you post connections to your driver pcb or schematic
it would make construction of amp easier hoping you can help out
warm regards
andrew lebon
HI CHESTAP
warm regards
andrew lebon
HI CHESTAP
it would make construction of amp easier hoping you can help out only need connections of bridge how to wire them power pcb is almost ready
warm regards
Andrew lebon
is this the limiter ?
hi cheshtap.
what is the power of this amp, i mean watts for 8 ohm,4 ohm, 2 ohm.
amplifier
hi chestap
greetings can you please tell DC PROTECTOR RELAY VOLTAGE
1 turns and swg of output coil
2 how to bias AMP SETTING VOLTAGE OVER EMITTER RESISTANCES
THANK YOU for helping out
warm regards
andrew lebon
hi chestap
warm regards
andrew lebon
Hi andrewlebon
Sir
U made apex vertex
Plz Send apex vertex sound quality and its performance and its wattage.
Sir
U made apex vertex
driver pcb dimensions
hi khalsa
greetings driver pcb length 14cm breadth 7 cm
warm regards
andrew lebon
hi khalsa
warm regards
andrew lebon
- 900W H-class PA Amp with Limiter
