900W H-class PA Amp with Limiter
Class H is first time for me, have simple question...
Can I use following transformer for APEX Class H Step Driver
Input AC: 230 V
Output 1: SEC 55 - 0 - 55
Output 2: SEC 55 - 0 - 55
Output 3: SEC 15 - 0 - 15
it comes from defectice Ebay Class AB PA amplifier with + / - 140 V Rail
I have also a trapo
OUT1,47 0 47
OUT2,47 0 47
out3 24 0 24
I ask mile about this and he reply it can be used modifying the output in series
94 47 0 47 94 vac
maybe yours also and just use 100 volts or higher caps for PSU
@engel dela pena
Im also trying to figure it out why TL072 wont trigger
But crown amps uses same step drive tl072
H900 WOW!!!
I just installed the TRAPO 40x4 30 amps and the result all i say WOW so VERY LOUD
picture taken feed input 50/100 hz sinewave and measure the output with multi meter the AC reading on output is 110v ac full volume no load
yes i will never forget what i promise to you,,APEX say you never go back on AB when you Made Class H,,and its realy true..
na try ko ngayun ang 10 pairs ni e,,,...n bro d ko type sound napakalayu sa b500
not good like squarewave sound ,,Apex design are Very good and trusted that work great,,btw i still use those power trans on other h900 of apex
HHAHAHA i Have 20 pairs of it,,i bought 22 pairs of power output i thought is very good and powerful heheheh,,anyway its good experience
