Hi folks,
I'm serching for a circuit to convert 9vDC to 48v DC for a mic that needs phantom power.
Sennheiser sells an adapter like this,but it's expensive, so I'd like to build one myself.
Any information on this is apreciated
Tks.
Ric
Tks.
Ric
You should look for either a charge pump(SwitchingRegulators) or DC-DC converter.
DC-DC converter are costly.
A good start could be a look at National semiconductor web site for SwitchingRegulators (step-up) .
www.national.com.
you can also search Digikey site
www.national.com.
here's a lot of info on phantom power:
http://www.hut.fi/Misc/Electronics/circuits/microphone_powering.html
if you have a wall-wart which delivers AC you can use a voltage multiplier (tripler, quadrupler, whatever) -- this will be quieter than a switcher -- you can regulate 48V with a LM317HV or a TL783 (which will go to 125V)
have a look at mpja.com
surplus site w lots of dc dc converters
otherwise oscillator driving multiple stages of voltage doubler
those keywords should find a cct
5 batteries is an option, but since the microphone only needs 2 ma of current at 48V I thought that if the circut is not very complex, it could end up being more compact that a set of 5 batteries.
Weight is another problem. This microphone feeds a camcorder in a Steady cam mount, so weight is of outmost concern.
cheers
Ric
PD: tks for the links, folks.
cheers
Ric
almost all electret mikes (I suppose that's what you've got since it needs only 2mA) work with smaller voltages. Try yours with two 9V block batteries and, say, 2k2 1% resistors. Also, you might want to bypass batteries with small block caps.
Regards,
Milan
Regards,
Milan
MK60
I do not have that luck, Moamps. The mic is a Sennheiser MK60, a beautiful shotgun that needs 48 V +_ 4V according to the manufacturer.
tks anyway.
Ric
tks anyway.
Ric
One approach
use a MAX1771. It's not the latest/greatest, but will work, has a free sample, and come in an 8-pin DIP package.
Re: One approach
Tks for the data. I never used such that chip. I downloaded the PDF and it suggests this:
"The MAX1771 drives an external N-channel MOSFET switch, allowing it to power loads up to 24W. If less power is required, use the MAX756/MAX757 or MAX761/MAX762 step-up switching regulators with on-board MOSFETs"
Which I thing is better because is more compact and I need a few MA anyway. But I can not find any reference that points at using these chips in a 48V output configuration. Any ideas?
tks, Ric
thespeakerguy said:use a MAX1771. It's not the latest/greatest, but will work, has a free sample, and come in an 8-pin DIP package.
tks, Ric
head over to national at
www.national.com
use the webbench power tool and input ur requirements...it will come up with a nice schematic and simulation for whatever you want...takes just a few mins...I'll recommend the LM2587...
www.national.com
Great data
Tks a lot for the data. That tool at National is really great. I'll give a try to the IC you suggested. I sounds like the right part to use.
cheers
Ric
cheers
Ric
- Design & Build
- Parts
- 9 volt DC to 48V DC
