841 DHT Hybrid Headphone Amplifier
Thanks, SS! That RCA pair of globes are the only ones I have, every other pair are the ST Hytrons, the most common in my experience too. Wow, never came across a Raytheon 841, I'll have to keep an eye out. There is a fella with some really nice NOS GE globe 841 on eBay, but asking quite a pretty penny for them. Switching everything to TO-247 is probably a good idea, I'll keep that in mind 🙂
Here's a picture I found on the net of the Ratheon version. They're built like tanks.
Man, the box plate Raytheon is stunning, would love to find a pair of those. The RCA appears to be identical to my pair, the only other globe 841 I have come across are General Electric and euro21’s smooth plate Radiotron.
This is my globe 841 collection.
3 pcs. Taylor VT-51, one Deforest 841 (the other's filament died :-( ), one Radiotron UX-841.
I'm searching Taylor and Deforest, but nowadays the (HUF/USD) exchange rate is in the skies. :-(
I recognize this design is somewhat silly with the high B+, impracticality of the 841, heat dissipation, etc., but that is the joy of diyAudio, building things because you can, not because you should 🙂 open to ideas, otherwise I will update here if and when it comes to life.
Could you not look at a folded cascode? You'd be able to keep a high headroom without needing a high B+ to give the stack room.
Nice tubes euro21, beautiful Taylor globes, maybe I have seen those once before but I cannot remember where.
Hi Nick - I am not intimately familiar with the folded cascode topology, it is something I have been meaning to look into, thanks for the suggestion. Too late to change course on this amplifier though as the chassis and layout are finalized. The 841 biases at a high plate voltage, which is the primary reason for the B+. In my prototype, plate voltage is 375V with a 460V B+ which gets me right about to the 500mW power limitation of my Sowter 8665 OPT.
"maybe I have seen those once before but I cannot remember where"
I bought these (one pair, and the single) via ebay at 2014 from different sellers in USA.
The average price per tube was then about 90USD (include shipping), now the shipping itself sometimes exceeds even 30-40 dollar. :-(
Should have the chassis for this amplifier any day now, I've attached some photos from the gentleman who machines them for me, powder coated in a metallic gray.
I also made a big purchase the other day, the etracer curve tracer. Attached are some A1 and A2 curves for the 841. Some interesting applications at a positive grid A2 bias point perhaps, although this amplifier is A1 only at a very modest bias point, the tubes should last a very long time.
Hey thanks, SS! The etracer is a pretty cool little unit, but not cheap by any means :/ luckily I have been working overtime lately.
Wow 440Vpk-pk, need to go back to your blog and refresh my memory on how you are using them, they can swing some serious voltage, think I'll find another circuit for them some day. My little headphone amp is sort of an odd use I admit, but it sounds great. I have them CCS loaded as well, 6mA, 400V on the plate and roughly -3.75V on the grid. They'll swing something like 150Vpk-pk which is plenty to drive any headphone to ear-destroying volumes with the output transformers I'm using.
Here are just the A1 curves up to 15mA.
I'm using the 841 as a driver for a Unity-Coupled (50% cathode feedback) output stage. It's a really linear output stage but it's basically a 1/2 cathode follower so takes a lot of voltage to drive.
I did experiments with the few smaller tubes I could find that could take a 400V idle voltage. I compared 841 to 6SN7 and 6BL7. 841 had the lowest distortion but 6BL7 was pretty good. 6SN7 doesn't do all that great for that much swing. The lower distortion and bright filament of the 841 really sold it for me.
I was also considering some of those smaller transmitter tubes you are looking at, but I wanted to avoid exposed voltages if I could.
Finally making some headway on this amplifier. Prepped the chassis last night - sanded away powder coating overspray on the top plate and mating faces of the side panels to get a good ground connection.
Started mounting parts as well. My recessed socket design turned out well! Looks really nice with a pair of globe 841 in place. Should be able to finish the amp by this weekend.
I like the recessed mounting with plates under the chassis. I've got something similar planned when I make my 826 amp, so that I can have a hole in the chassis and different sockets that mount under the hole for different tubes. I also probably have to put a little fan under for extra airflow.
I really like the chassis and I might have to try Landfall out for my next project.
Where do you get those 4-pin sockets? Those look really nice and I will need some sockets for my 100THs.
