The topic has ben opend before, but not answered.
Could one make a 1 tube stereo SE amp with this?
The common approach is to ho pp with these, because the screens are common.
But, i i'd make a regulated screen supply, does that matter?
in PP the both halves have very different (180 degrees) signals to work with!
If i would go for grounded kathode, fixed bias and regulate the screen supply. Could i make a stereo amp?
Bas
Bas
I don't see any reason why you couldn't use them, but you would still need a driver tube so it would be at least a 2 tube stereo amp. The characteristics look like a sweep tube (a small one) and you could use a similar circuit. Other than the uniqueness factor I could think of better wasy to make a 2 tube stereo amp (2 X 6EM7 or 2 X 6LU8).
well,
I have this tube, just this one tube.
I have a cool fullrange speaker and one output transformer to go pp
I'd like to fiddle around with the tube. Then this "could i" q popped up.
the 2 tube thing isn't that much of an objective, though a nice thought.
maybe the fullranger wit this tube in pp would be an ok center speaker/amp, in combination with my big pp for front and my ecl86 stereo for rear....
but that's far future😉
