I am looking at using the 829B in a single-ended application with both halves in parallel. What can I expect for dissipation per plate? The data sheet is misleading, as it is assuming intermittent operation in an RF amplifier. What would be a good plate and screen voltage?
Take a look here...
http://www.pmillett.com/829b_amplifier.htm
From Pete
I'm running the 829B's at about 80mA, B+ of 320V, with cathode bias. For details look at the schematic (below). I don't seem to get a lot of difference varying the bias from 60 to 100mA.
From Pete
I don't think I want to be running the 829Bs in triode mode - perhaps I'll use a depletion mode MOSFET front end and run parallel pentode mode, with Schade -style feedback. The big question is, what do I use for screen voltage? I understand that the screens are hooked together with a common bypass capacitor. I guess I can set the screen voltage by experiment, maybe starting at around 200V. An active shunt regulator would be a nice way to regulate the screen voltage. The grid bias will be by guess and by-golly as well.
This Mazda datasheet for the 829B contains data for use as an AF modulator in class AB1:
829B Mazda
According to this info by Mullard the value of the internal capacitor between the screen grids and cathode is 65 pF.
829B Mazda
