807 PP with 8k primary imp OPT?
Recently I was given a pair of SOWTER model U082 output transformers.
SOWTER TYPE U082
They are good for EL84 type tubes but I am keen to know if these can be adapted for 807 tubes. I have seen the STC datasheet and the mention of running 807's into 8k primaries. These are pretty generously proportioned heavy products.
Tubes at hand include small signal triodes of 12AX7/U7/T7 family. Several 6SN7/SL7's. 68J8 family tubes. And several pairs of 807 NOS tubes.
Some might suggest to follow the Williamson design. If the Sowter type U082 ironware is suitable then I would surely go ahead. Unfortunately I don't have any T&M setup to verify. I do have a few digital multimeters and a surplus 5A variac. At pinch I can buy and learn to use a cheap oscilloscope.
I have experience building basic tube stuff to a print. Such as SE EL34 type amps, linestages etc,. I am an industrial worker thus aware of the hazards including those arising out of 807 having a top connection.
Before committing myself to this project I wish to absorb as much as possible. Would strictly try not to use any complicated CCS and other fancy stuff.
I will still be required to procure the power transformer, chokes, casings and other bits. Planning to make it a weekends only slow paced build in a monoblock configuration.
Looking forward to ideas and help.
Hello, re your U082 transformers, what secondaries do they have ?
DavidBohmfan,
The data sheet says 8 Ohms.
Were you hoping for:common, 4, 8, and 16 Ohms to be able to ground 4, and use Common and 16 Ohm for cathode feedback?
The transformer is built with very many layers of interleaving, and with a single 8 Ohm output, is probably the best it can be.
But to wind it with a common, 4, 8 (9), and 16 would lower the performance of that transformer.
Just my opinions
Reactions: DrowningNotWaving
12.5W @ 8 ohms = 10V rms. That is 14.1V peak. Using the Sowter U082 it has turns ratio 31.6 : 1. The primary peak will be 14.1 x 31.6 = 445V. You would need some 500V B+ or more. The 807 can't be triode connected (or UL) in this case, because the g2 voltage is limited to 300V. (Although I am using it in UL with B+ 350V without any issue).
Reactions: Marco audio
I looked up some data published by MJ some 30 yrs ago.
Triode connected 807's : Vb= 400v
Rk= 330 ohms (common)
Zo= 8k
Ia = 116ma (2 tubes)
Po= 10,8w
My amp allows me to adjust the b+ and bias per tube. It uses Monolithic Magnetics 8k transformers. Looking around for operating points for the 807 in triode PP I came to Duncan’s and saw that it recommends 320v 40ma into 8k for a whopping 6 watts of class A power. It is also claiming .6% of THD though without any details on how that measurement was made. I gotta say, the amp positively sings with these settings.
https://tdsl.duncanamps.com/show.php?des=807
Saw these numbers above from Morgan Jones and thought I’d give them a try. More power is better right? I don’t have any way of measuring my amp but it really didn’t sound as good at these settings as compared to the ones from Duncan’s. The bass is weaker and there seems to be a haze throughout the range. I wonder what is going on? I am running Cossor branded vt60a tubes which are supposed to be equivalent to the 807 but maybe there’s a difference at higher powers? They certainly work incredibly well at the figures for 807 on Duncan’s. Or maybe there’s something in the circuit or transformer or whatever. Point is that you might want to experiment at different operating points for best sound. I know people cringe on getting that few watts out of a pair of 807 but it works well with my speakers and listening habits.
807s will run in triode mode with up to 400Vp. Early American Williamson amplifiers used the 807 this way and they were found to hold up fine. You can get 12wpc from triode-wired 807s, depending on the load. The Stancor Williamson kit ran therm just this way and you can find examples of these amps with the original 807s still operating.
Sure. I guess my question is what operating point sounds/measures better? Given the same transformer, would we expect the same performance at 320v 80ma vs 400 116ma? Obviously there would be more power at the higher voltage but it measure as well? I assume Williamson was aiming for max power, did distortion or sound quality of sort suffer to get that power?
Why would you use the same transformer for push pull triode wired 807 tubes that have quiescent voltage and current of:
You might have a higher damping factor in the Class A region of one of those two setups.
You will have to look at the triode wired curves, check the slope of the plate impedance, rp, at those two different operating points.
Because that is what is in my amp and I can set those operating points. Like I said, the 320v sounds great but thought I would try the higher operating point because why not? The amp is designed to allow me to use different operating points, potentially with a few different types of output tubes. I’ll admit to not knowing why one operating point will work well and the other does not. This is the transformer in my amp:
http://monolithmagnetics.com/sites/default/files/B-8_8k_0.pdf
And this is the amp:
https://www.head-fi.org/threads/oblivion-ultrasonic-studios.902926/page-444#post-17216420
I don’t remember whIch circuit design was used but it was a pretty standard one, no gyrators or followers or anything. The B+ is regulated and can be run between 250v-400v. The regulator is rated at 20 watt dissipation. The upshot to that is that I am limited to 30ma per tube when I run it at 250v But can apply more as I go up in voltage.
Anyway, I don’t know enough to know why the different operating points sound different. Was hoping to hear some likely explanations, hope the info wasn’t too vague.
