8 inches paper cone treatments
Hi to all! 🙂
Has anyone tried "Rehdeko cone treatment" or other similar (NOT "EnABL") cone treatments with 8 inches fullrangers?
here is Weber Rehde's patent description:
http://www.freepatentsonline.com/4100992.html
I have Fostex FE206E. This particular driver suits my needs very well, almost perfectly BUT it has a big problem 🙁
it is sharp nasty ringing (=howling) resonance at around 2.8 kHz. I know that it is a break-up resonance of the main cone - not of the whizzer
I wonder how it could be effectively treated.
best regards,
graaf
i used "Ponal" as coating for paper cones with good results.
Another possibility is to use a small aluminium pipe, bend it
as a ring to stabilize the cone along a certain radius.
Use an appropriate glue, not too hard and only very little
amount . You can use a piece of a toothpick e.g. to close the
ring tightly.
In both cases it is useful to know, how the breakup mode
looks like. I have used cork powder to visualise it with some
success so far ...
The "Ponal" wood glue applied to the whole cone ia a good
broadband "quietener" but to do selective damping or bracing
to save moved mass is preferable.
If the picture you have posted shows the breakup mode
correctly, maybe an alu ring stabilizer placed slightly outside the
phase coherent center of the cone would work -
just a gut feeling ...
Cheers
thanks You GM and LineArray for Your interest and suggestions
correctly,
a qui pro quo - the picture shows one of the cone coating patterns that can be found in Rehde's patent
what I found most interesting is that He recommended coating of only part of cone area, sometime only a small part
I have made some tries with Fostexes and the posted pattern is mostly similar to the one I used
mine looks more like the "radioactivity symbol" and coated cone surface area more or less equals the uncoated
I chosed it because I wanted an asymmetric pattern - I read somewhere that it is good to break the symmetry of the cone because most harmful are axis-symmetric modes
I have also used a kind of glue but cyanoacrylic
I chose it after some tries on sheets of paper. The cyanoacrylic glue seemed to penetrate the paper best and to stiffened it most
Weber Rehde recommended "varnish of cellulose type" (nitrocellulose)
I have tried nitrocellulose based nail varnish on sheet of paper and it seemed to work less effective than cyanoacrylic glue
Unfortunately I cannot do any genuine measurements but a "measurement" I did using DEQ2496 RTA function and ECM8000 showed that after the treatment of the FE206E resonant frequency response peak got a bit smaller and shifted from around 2.8 to around 4 kHz
audibly it certainly became less offensive but not enough, therefore I think what can be done next/better
what do You think of applying the treatment only to a part of the cone - like in Rehde patent?
Have You tried Stabilon and Vinylflex paper cone treatments offered by Intertechnik Deutschland?
they are both polyvinylacetate based but the first is said to be a stiffener and the second to be a dampener
what about treating of half of the cone surface with stiffener and the rest with dampener? what do You think?
best,
graaf
best,
graaf
i found that thinking too much about cone treatment,
breakup modes and coating drives me mad.
I modified lots of drivers and basically i think that someday
you will end up with building drivers by yourself.
An 8 inch fullrange will inevitably suffer from breakup to
a certain extent. I basically think you cannot win using
a stiffener. With a paper cone, a dampener is the way to go.
Most paper is stiff and has little damping, you have to add
what is missing to get a composite material with better
habits.
"Ponal" introduces some stiffness but is mainly a dampener.
If you bend a sheet of coated paper and watch how it
goes back into its shape, you get a feeling how much damping
is introduced by the coating.
One way might be to make a foam of the coating material
to increase the thickness of the coat and keeping mass low ...
When moved mass is an issue, i think it is preferable to
coat only near the surround, but i have litte experience with
fullrangers. For most bass and midrangers a total area coating
will give best results IMO.
With some drivers i had good results introducing slots into
the cone and then closing them with a dampener ...
Very expensive experiments, maybe get some cheap and
evil sounding drivers to practice ...
At present i do not want to spend much time in modifying
drivers anymore, i think it is better to use drivers of smaller
size. Unsufficiently damped breakup modes are worst in the
nasal to precence region from 1-6 Khz, if you find a driver
which behaves well in that range one can tolerate some
uncontrolled breakup at higher frequenies.
Since you cannot supress breakup totally in my present
fullrange design i use multple drivers and balance them
taking advantage of the tolerances of individual drivers.
Using that method i obtained the best results ever, thereby
keeping the need for compensation in the XO at minimum.
Cheers
habits.
stiffener moves break-up resonance higher in frequency
isn't it reasonable to move it higher? in case of my FE206E moving it from around 2.8 kHz to around 4 kHz was certainly beneficial to the sound quality
for conventional front firing speakers it would be also my choice
but I need one fullrange driver to fulfill my "room/loudspeaker interface" design priorities
best regards,
graaf
ps.
any more experience with coating of fullrangers anyone?
help please! 🙂
I use liquid bitumen
With a very thin cone you may have to stiffen it first with something hard first
But be aware of likely loss of sensitivity
Also such FR drivers usually have very small voicecoil with short Xmax which may not be able to deal with the exstra weight and new lower Fs
Hi graaf,
i think it is a success to move the breakup from 2.8 to 4 Khz,
if it was a midranger then the difference would be between
nasty and perfect.
But i think in your case the resonance must have become less
prominent too, otherwise you would not feel it sounds better
now.
Moving resonance up in frequency is a way to go for midrangers
but what to do with a fullranger ? If it is a whizzer cone design,
maybe moving a resonance above the mechanical XO of the
whizzer works well ... so in some cases stiffener would be
in the race again, don't know.
habits.
paper is not that stiff
fortunately it has "some" damping
interesting papers on physical properties of diaphragms:
http://www.fostexusa.com/support/pdf/fostex/nf1/nf1_tech_white_paper.pdf
www.infinitysystems.com/home/technology/whitepapers/cmmd.pdf
these are manufacturer information brochures of course, nevetheless presented facts and measurements are interesting (especially in the Fostex brochure))
nasty and perfect.
yes indeed, therefore I think that this modification is worth to be further researched and perfected
this seems to be "the way to go" with a fullranger
now.
I agree
on the other hand I wonder why it has become less prominent. Is it a matter of added damping? or perhaps the diaphragm itself has more damping at this higher frequency? or perhaps this is a benefit of introducing of an assymetrical pattern in the diaphragm?
best,
graaf
what do You think of treating some parts of the cone with stiffener and some with dampener?
taking the image attached to the first post as an example - treating the grey coloured parts with stiffener and the rest with dampener? or the other way round?
or yet different - treating the grey coloured part in the center with stiffener and the radial coloured parts with dampener leaving the rest untreated? or the other way round?
so many options 😕
does the theory of cone diaphragm suggest best/optimal one?
has anybody tried such an approach?
best,
graaf
Hi graaf,
Single circular drivers tend to generate much more noticeable 'dissonances' (than elliptical) at frequencies related to radial symmetry.
Circular drivers offset on a baffle, or those mounted in line with others can sound better as the symmetry of transverse wave motion at the driver perimeter becomes less 'focussed' with respect to the cone and its centre.
I have found that modifying mounting arrangemets or interfering with transverse wave symmetry can do much to improve reproduction without anything being done to the cone itself.
To me, LineArray's spacing inconstancy will have a significant effect in randomising frequency dependent transverse wave pressure effects upon circular cone apertures, and thus sound less dissonant than a single circular driver or a conventional close spaced line.
Try foam fingers (off mini paint rollers) to reduce air-side wave symmetry within the driver perimeter. Here in front of a B200.
Cheers ......... Graham.
best,
graaf
I remember some studies from Celestion / UK concerning
the bass midrange unit of the SL6 bookshelf speaker.
They did lots of analysis with laser holographics on
that diaphragm. As far as i know they ended up with a
material which has high damping, but they varied thickness
of the diaghragm in radial direction. This way they obtained
a cone which shrinks in a "non breakup" or at least
rather smooth manner with increasing frequency.
To mimikry such behaviour with a thin paper cone, i would
suggest to treat with dampener at the outer area near the
surround. If it is a fullranger maybe introduce a small ring
near the surround and then make it successively wider to
see what happens with every step.
Leave a middle ring untreated and start again from the
center using a stiffener.
I think, a whizzer design has to be looked at differently than
a single cone.
But one has to deal with the real object, we will not find an
all purpose method - just by discussion - which fits to all
diaphragms.
so many options 😕
best,
graaf
Liquid bitumen is quite effective, but the problem is that it is quite heavy
I have had some luck with polyurethane glue, it is very light but leaves a rugged surface so it was applied to the backside
From time to time Dammar Harz has been mentioned fore light paper cones
Natural harz lacquer like shellac can be altered to soft hardening by a drop of oil or very little amount of bees propolis ... maybe it gives a more natural tone 😉
Graham Maynard said:
Hi graaf,
Hi Graham,
since i am playing with drivers, i feel the tendency, that
oval shaped ones - especially fullrangers - tend to a more
benign behavoiur than comparable circular ones.
I agree with you that even without breakup modes, the
concentric radiation of the air wave and reflection from the
border of the diaphragm is not very beneficial to uncoloured
reproduction due to interference effects ...
Also the distribution of bending waves along the cone,
may be more smooth in an oval shaped diaphragm.
Of cause there are fewer oval high quality drivers than
circular ones, so a fair comparation is difficult ...
Briefly, this is exactly what the upper section of "Dipol 08"
is optimized to.
Especially the arrangement of the upper 3 drivers on the
baffle was chosen, to have the least possible disturbing
impact of interference on the response.
Do you think that breakup modes and airwave interferences
are interconnected to a significant extent, when assuming a
thin paper cone e.g. ?
@graaf: I was thinking about your suggestions. Why not
use the alu pipe ring stabilizer in the center - which i mentioned
before - and a dampener as coating near the outer suspension ?
Will be tricky to find the best diameter of the ring stabilizer, and
the best witdh and thickness of the damping coat, but i
think this combined techniques could have some potential.
A friend of mine was experimenting with those ring stabilizers
some years ago and we tweaked some cheap fullrangers
in an astonishing way using that. This way you get real stiffness
you know, it is not comparable to a coating using stiffener ...
Cheers
Hi LineArray,
I too made a tall (6ft) 'line' with uneven spacing, and it sounded better than a minimum spaced regular line using more of the same drivers. Your picture reminds me of this finding, though I did not take my own construction any further.
I can understand the benefits you report because the line does not detract from individual driver quality by imposing a regular 'spacing' dependent characteristic.
You ask
thin paper cone e.g. ?<<
YES!
Thinking about this further makes me wonder if it would be possible to use foam rolls or pieces behind a single driver, very close to the cone though clear of its X.lim, in order to prevent symmetrical surface pressure pattern induced break-up. This to prevent an avalanche mode into break-up by modifying pressures acting upon the cone.
Behind the cone would be less 'odd' looking too.
and YES again.
If only the LS driver manfacturers would come up with a high quality widerange elliptical.
The best I feel we can do is keep the air length paths from being symmetrical all around.
Cheers ....... Graham.
Hi LineArray,
You ask
YES!
when thinking on closed box designs
(also backloaded horns etc.) , one might think whether
standing waves inside the box behind the driver influence
cone breakup modes too. With large area thin paper cones
this might be a serious issue.
To build an absorbent jacket around the drivers at the rear
side is of advantage in many cases.
I use such a jacket in my OB design to get the rollof from the
rear more smooth, so i can XO it in a more definite manner to
the tweeter panel, without using an electrical lowpass.
The jacket changes midrange to high distribution into a more
cardioid shape too ...
In my street is a hatmaker, i talked to her on friday last week
and maybe she will make some more beautiful jackets for my
drivers ... on the pic posted before the jackets were taken off.
This is not quite what you thought about, but your idea is worth
thinking.
Cheers
very interesting!
does it work (is it needed?) also if one listens extremely off axis?
(my Fostexes work in a Carlsson type omnidirectional setup)
are there any measurements showing how the rollers work?
best,
graaf
circular ones...
I wonder why?
LineArray said:
Why not
yeah, why not? 🙂
but I am not sure I understand well what to do
can You post a diagram, a simple schematic of this modification?
best regards,
graaf
hi graaf,
here we go ...
1.) Get an aluminium pipe from a model building shop.
2.) Bend a piece of pipe into a ring using a cylindrical object,
of somewhat smaller diameter than your desired.
3.) Close the ring by inserting a little piece of a toothpick,
tay stick or similar material with some glue into both
ends of the open ring to get it close tightly.
4.) Glue the ring onto the cone.
5.) Apply your preferred dampener using a rotating device
(turntable) and a brush to the outer ring.
6.) Let it dry.
7.) Listen.
Some schematics: Dark area is inside the ring, white area is
untreated, grey area is treated with dampener.
Dimensions and relative size of the areas and the ring have to
be identified by your own research on the particular driver ...
