SSHV2 Vout is jumping like Vin
I have two secundaries 250VAC 0.8A in parallel, only one secundari of 80mA be enough to power both channels 20+20+20 SSHV2 = 60mA?
if it's only a power amp , where is the preamp ?Nice. Nonetheless, that's a power amp.
Maybe it has enough voltage gain to be fully driven by a laptop's output. Like an integrated. Its builder may enlighten us.
I know is enough but there is hum not buzzThat's 80+80mA=160mA*0.63=100.8mA with Cinput bridge rectifier
Hum can be a ground loop? Measure Hz or look with the scope. If its mainly 100Hz its ripple, if its mainly 50Hz its ground loop or magnetic field interference.
How much is it now?I'm gona increase mains filter capacitance.
If DC is clean of frequency it should be a loop or interference. Microfarad bank seems enough for a preamp. True RMS AC mode or DC+AC mode in your Brymen can show how much ripple you got on the filter bank.
Ouch. I hope it self healed.The 24uF film was low rated at 250VAC
I had it on the chassis from old for passive CLC PSU but its not strictly necessary to be 470uF when there's a regulator or a Mosfet cap mult following.I see you use 470uF
Has your SSHV2 output been steadier? Clean line on the scope too? (Always set scope's probe X10 when for HV to be safer).
It's increasing voltage very slowly, I see each number how increase each 10mV, once seen change for other more elevated, like a count up.
- Tubes / Valves
- 6V6 line preamp
