6C33CB PP amp with ultra linear
30Hz seems to be OK just about full power 80V ppk. 20Hz power is 3dB down. Therefore sounds OK with the 1650M, will add a input HPF to cut in a little. Plan would be to pair them up with some mid range small floor standing speakers so these with be down at 40Hz.
This is the KT88 design which is similar but with lower voltage transistors. You want high HFE PNP. The 100K is 2W. Q4 allows you to hold off the bias until the tubes are warm. I saw the toroidy did not look there. 1k2 may give you most drive at about 6R which is good for many floor standers which often contain 2 bass drivers in parallel. Looking for better sockets for the 6c33, the ceramic base ones I have the tubes drop out of.
Reactions: astouffer
