Hi guys
I'm working with this Apex B500 new PCB board and I just want to ask someone that it is ok if I add the extra pair of 2SA1943 and 2SC5200?
Hi guys
cant see picture...
actualy there are 3 leds on that kit, orange for signal input, red for clip, green for power....If u want this diagram go to post #1286 on page 129. (why u lazy to read this forum from beginning).......regardshi yosie,
what purpose you use orange led and red leds ?
can u share the diagram. or pcb layout.
is this correct one?
did u checked?
yes....
hi yosie.
can u share the pcb layout in pdf, because i cant edit the original b500.
thank u.
.Sorry, I don't have the pcb layout in pdf, I used the layout and diagram @post #1293 on page 130, thats all.......regardshi yosie.
thank u.
Sir my 2nd project after ax-14,b500 but I dont have nsl 32 component and build b500 with voltage 60V +-,R24 and R25 change 1k5/2w but very hot.Sir can u send me schematic installation of b500 how to connect with pro and limitter,sorry my english and thanks to Mr. Mile with b500 nice sound.
pls help
in my b500 i power on, then the transformer giving a sound like generator. so i off.
i checked transistors ,c5200 three transistors burn. but fuses are not blown.
so i am asking if ouputs burned the transformer giving sound, that mean the transformer will burn.
for this what is the solution?
you should have used a bulb tester at each stage of construction to power up and check your wiring.
hi andrew t
can u share the diagram of bulb tester.
is it ok 100w bulb. thank u.
You can find what you want on this thread.........try the bulb series with you PA......good luck, brohi andrew t
are u shure?
not shure....
hey nazidigi...not shure...that is a brand of microphone....sure...yes..that is correct...do a search for light bulb tester...way way back in this thread..
are u shure?
and dozens of other threads.
There must be approaching a 1000 links to the tester and a dozen or so detailed build/assembly instructions.
Mr.Mile can i change MJE15033 with other transistor?? Because in my place i can't get it..
Thanx
Thanx
vorezky04
2SC4793/2SA1837 is replacement for MJE15032/..33
You can also use 2SC5200/2SA1943 as driver or some similar...
- 500W PA amplifier with Limiter
