I see no need to replace the case. After studying it some more the 1/4 jacks input say they are balanced and have a pcb w ac power going to it and 5 wires going to the preamp....I'm thinking I need remove these 1/4 jacks/pcb and replace them w some rca inputs, then run the wires from the new rca inputs to the 125asx module inputs. Then it should work again?
No not really any diff I notice, this is just my garage system, running late 60's Pioneer speakers. I'm just glad it works again, and the unreliable preamp is done with.
The preamp of my Vocopro also stopped working recently. I made a simple bypass and the ICE power module seems to work perfectly. I want to use it in BTL mode, therefore I have ordered an unbalanced to balanced module on ebay that I plan to put into the cabinet. Do I need any of the Vocopro modules or can I take them all out?
bypassing preamp board
Like Vidareje, my preamp board seems to be bad also. I was under the impression that i needed a phase inverter / balanced driver board to do a BTL with the icepower 125asx2 board. However i was looking at the data sheet linked below and as i interpet it and the figure #17 on page 24 it is possible to run a single ended input parallel to both channels. Am i mistaken? I think that the downside would be a 3db or 6db attenuation. Or will it fry the amp or my speakers?
https://icepower.dk/download/1636/
I tried to post an image of the exact page 24 but doing so escapes me.
BTL connection
Menlobob, Thanks for the quick response. For now i'll hook it backup as 2 channel and single ended. That should also eliminate the chance of the 125asx2 being the problem, which I doubt. And wait for a driver board. 😀
I brought one of these on Ebay. I will mount it this week-end (took six weeks to get it to Norway from China).
12V NE5532 Unbalance to Balance Converter Board fit Differential input amplifier 699934683566 | eBay
One thing to watch for on that board is the size of the input power supply capacitor if you plan to power the board from the AUX power supply of the module. See page 6 of the 50ASX2 designer's manual. You need at least 3 ohms of series resistance.
Hey menlobob, do the Ghentaudio modules have input series resistors? They never responded to my email.
I used the power to the input stage (14V),removed the fan (never ran) and the input card.
I could also use all the original cables.
The board fits in there nicely. How does she sound?
Don't mean to complicate things, but it would be better to have the input jack on the same side as the input board. It would be a very short connection to a jack on the fan side, and you could use the shielded cable for another project. It's not ideal to have the input cable cross over the amp and SMPS. One of the first things I did with this amp was pulled the original input jacks/board to the other side, and it did improve the SQ.
- Class D
- 500W of ICEpower for USD$100, deal or not?
