5 band tone control
What exactly do you intend to drive it with? What logical reason is there to not set the input impedance at a more op amp friendly 10K? Or industry standard 47K?
The fact that you ask this question tells us you're shooting in the dark.
You are answering question with questions - that is impolite.
What to drive it with - any (decent) opamp buffer will do.
Any more explanations for declaring this "very very wrong" - perhaps some argumentation?
Reactions: ejp
At least you have provided reasosn why not to use some of the circuits rarher than come out with unhelpful Smart Alec remarks like "trust me".
2.2k input impedance need not be a problem if the preceding stage had a low output impedance, which most op amp stages have.
Would you set the input impedance of your preamplifier to 2.2K? Why or why not?
There are good reasons to set the input impedance of a line level circuit. What is the good reason for setting it so low here?
I think a couple of those circuits were lifted from a larger modular or integrated design, where there were good reasons to set the input impedance there.
It would depend on the preceding stage, as I have said so it's pointless to second guess the designer's aims and also, we don't have the full schematic.
Of course. And without specific input from the OP any attempt at helping them would be second guessing.
One of the circuits was a buffered control already, and all that needed to be done to make it a turnkey circuit was to change a couple of resistors. You could have had a complete stand alone turnkey circuit. OP suggested buffering the buffer, which would work but the same result could be achieved by swapping resistors.
It's easy to take classic circuits and improve them with today's parts. And there's a way around virtually every shortcoming in many circuits. To me these things are obvious now but I clearly remember not being able to figure out why my circuit didn't work, or why they fell short of specifications, etc. I want to help people develop these skills now, but I can't force them.
I've been experimenting a lot with various tone controls, hard wired equalizers, higher order filters, crossovers, etc with great (but slow) success. This is the accumulation of decades of research and experimentation. I give a lot of people credit for helping me along. There's no shame.
Take frequency response measurements with RMAA with one band regulator at max position at a time.
Then select ("tick") these measurement sets and they will be shown in overlay mode (on top of each other).
NB! This display is a combination of independent measurements, when you maximize more than one control then resulting graph will be different.
I just walked one forum member through setting up the RMAA, I would rather not start repeating myself here:
https://www.diyaudio.com/community/threads/aiwa-aa-8300-restoration-ideas.396261/
  • Thank You
Reactions: chinoy
