I currently have a 100Wx2 Kenwood amp powering 2 front and 2 rear speakers. It distorts easily, and goes into protect mode with too much bass. I would like to upgrade to surround sound, and of course build the amp myself. I plan on using 2 sets of 2 lm3886 bridged for the two main channels, and 1 lm3886 for the rear speakers and the center channel. My sub is in progress right now and will use 4 lm3886 in B/P mode to get 300W into a 4-ohm speaker. Now, I need to find a way to decode the surround sound from the red and white analog wires from the dvd player. I would like to use optical or coax connection to make it easier, but all I could find was a 2-channel coax decoder from www.sound.au and was told a few months ago by people on this site that it wouldn't even work for dvds since dvds output digitally in 5.1channel mode, not 2 channel mode.
Is it possible (and simple) to build a decoder? If chips are required, they have to be something I can solder (a DIP would be great). I was going to build the 2 channel one and see how it works, then when the samples arrived, I noticed that they were tiny SIP chips.
Thanks for the help, Mike
Yes, Cirrus makes a 5.1 decoder chip, check out the CS492x series chips, i got a sample 492[something], not arrived yet, but i only requested it a week ago, and those things take time.. 🙂 good luck, and i'd like to know of any progress 😉 (thinking of building a digital decoder into my pre-amp, and emulating 2 channel sources into 5.1 etc... :/)
I also wanted to try building a decoder , but isn't it easier to get one from an old receiver??? And do some DAC/ADC/PSU/Clock mods to improve sound//😉
possibly, but when you dont have a old box and you can get free samples from Cirrus, why not at least try? 🙂
soundNERD said:Now, I need to find a way to decode the surround sound from the red and white analog wires from the dvd player. I would like to use optical or coax connection to make it easier, but all I could find was a 2-channel coax decoder from www.sound.au and was told a few months ago by people on this site that it wouldn't even work for dvds since dvds output digitally in 5.1channel mode, not 2 channel mode.
ok....
SMD Package
Don't want to dissapoin u, but it is Surely SMD - I expect PQFP/TQFP packages. I have no problems soldering down to 0.65mm interlead distance packages, only 0.5mm is a little bit difficult. And you will need a PCB for it, too.
I ordered samples of it, too, and if I have the time and money I can make a PCB for it, and some DAC/ADC's also. Is anybody interested??
Regards 🙂
Regards 🙂
Actually, is it possible to make a surface mount board using a laser printer and photo paper or press n peel. Or would the toner smear together. I would really like to just try building the coax adapter from www.sound.au.com just for the fun of it, but when I got my samples, I noticed that they are surface mount.
Now that I looked at my samples of the CS8414 and the CS4334 chips, the pins aren't that close, and if I could use my laser printer and photo paper to make a pcb for it, it should work good. Right?
It could be OK. Im fortunate in that where I am I have access to smt/pcb technology so Ive never tried the laser print and peel option.
It might be an idea to see if theres anywhere near you that can offer reflow soldering or a similar technique.
I soldered a o.5mm lead spacing package onto a pcb before, and whilst its certainly possible, you do have to be pretty delicate and be very mindful of the amount of heat you put into the lead. A small heatsink would be a good idea.
Re: SMD Package
Yeah figured, thats fine though that its smd 🙂... i can deal with it ... i can make a PCB for it, yet again not a problem... You could do that just like they are doing with the Aleph-X Boards.... unelss thats too big of a operation for you(which i can understand 😉)
machinow said:Don't want to dissapoin u, but it is Surely SMD - I expect PQFP/TQFP packages. I have no problems soldering down to 0.65mm interlead distance packages, only 0.5mm is a little bit difficult. And you will need a PCB for it, too.
Regards 🙂
How about making a normal 5/6/7 channel pre-amp, and using (if your dvd has them) the pre-outs?
There's a number dvds out there that do 5.1 decoding, unless i'm mistaken.
Then all you'd have to do is simply make a preamp w/ 5 channels (just a normal pre-amp), and then make 5+ separate amps for it.
elizard said:How about making a normal 5/6/7 channel pre-amp, and using (if your dvd has them) the pre-outs?
hmmm... no, that defeats the purpose,we [as far as i know] want an optical or coaxial sp/dif connectioon from [insert device here]... but i would like to make it part of a pre-amp.... i just lack the abilities to do so, so i'll bs about it until i know exactly how to do it 🙂
I guess I misunderstood the original post then. 🙁
You can't of course using the coax or optical connection with this, but its an alternative to building a separate decoder.
nFORCE said:
??... Mind sharing? 😉 hehe
why dont you try one of these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=1499&item=3063034610
i want to buy one when i will build my system!
only costs 35euros
only costs 35euros
KostasTheGreat said:why dont you try one of these:
only costs 35euros
because the only challenge in that is 35 euros for you or the equal USD for me... but if i were to build something, then its alot more nicer to me and i'd be less likely to break it 🙂 (Because i put hard work into it! 🙂) hehe
[and this is a diy board 🙂]
the CSr492x series chips are in a PLCC package, requires pcb... would it be possible to make a surface mount pcb from the kit you could buy at radioshack? [with the copper coated pcb and etchant solution with laser jet printable rub-off's which i could design a pcb for?]
- Digital Source
- 5.1 decoder
