4ch amplifier dc out to two channels
Hi!
What do you think the problem of this amp? I have 3 amps with the same problem. It muted with dc out 1.3v but the two channels working fine. They uses irs2092 as their driver to mosfets. Thanks!
No sound and 1.3v measured to all defective channels without load. Yes the output dc changes with load or no load. Ive checked all mosfets seems ok. No leaky mosfets.
3 amplifiers has the same issue.
Check coils, snubber circuit were good.
I think there is a weak parts on this kind of amplifier and needs modification.
Thanks in advance..
IF you do not have measurable (or very low) DC with an 8 ohm load and to boot 1.3V DC appears only when unloaded and muted, then I guess you "do NOT have a problem".
Maybe "nothing is broken" but simply under those conditions the output squarewave or duty cycle is not perfectly symmetrical and that´s read as a small DC component.
