350hz to 3.5khz open baffle......what driver would you choose?
Ideally sqrt(350*3500) = ~1107 Hz mean
~13543.8/pi/1107 = 3.9" eff. dia. = 4.5 - 5" frame
Closest drivers to the ones I preferred would be AlNiCo or neo Fostex or similar, though the 4" FE108EZ I do have experience with makes a fine ~inexpensive replacement with just a Lowther $0.97 tweak and make the baffle big enough to support the low end.
Reactions: ScottG
What you're suggesting is a 4 way then.....and kinda where Linkwitz landed with the 521 and an 8" midwoofer to 1khz and then handed off. I gotta say if i were to go that route, i'm not crossing anywhere between 1-3k.
Maybe as low as 700 Hz depending on baffle and max Spl.
So yeah: 2 drivers, particularly if you want to go higher than 2kHz which is best with a smaller diameter mid..
Might listen to Plott’s implementation here:
https://www.diyaudio.com/community/threads/my-open-baffle-journey.394806/page-11#post-7578142
He is currently high-passing the planar tweet at 5kHz, so that full-range 8” from Tangband is covering most of the mid.s and treble - and that’s basically what you are asking for.
Reactions: Pano
The best drivers for very wide band operation are not cheap:
Satori MW19TX
The Satori is slightly larger and I have been able to use it down as low as 200Hz when crossed over steeply (I use DSP) and up to 2kHz. All three can definitely work down to 350Hz when nude without a problem.
Interesting, how best to support the nude driver, tiny baffle or suspended somehow? I just bought material for a 35-40L cab (for MW19TX-8) but space and moveability are really important in my situation. I tried the TX in my albeit small 17L TLonken and no 50hz (60 even 40 were good); adding 50hz resonance sounded... resonant. I wouldn't want to build a cab and still needed a woofer or sub. But totally portable OB would be worth considering. (Then what's best continuing on down to 40hz?)
Greg please remind me what is the 97-cent tweak? (No archive.org access.) I thought the 108e∑ translucent floral cone looked too fragile for OB, but 350hz high-pass takes away the risk?
THANKS
So i've ordered a B&C 8PE-21 for baffle testing polars and see what comes back. Response is really smooth right out to 5k and they're very musical sounding not to mention crazy efficient. Basket isn't as open as i'd like but the polars will tell the story there.......i really doub't any rearward reflections will have an impact to the fwd response beyond a half db here or there.
Aurum Cantus 2560 planar is now looking like the likely tweeter option if the B&C proves to be all it can
Reactions: Arez
I have built a series of speakers where the midrange and tweeter are hung by wires within a welded-wire cage that stands on the floor. The woofers are located near the floor and not connected to the rest to prevent vibration transmission. In earlier designs I also hung the woofer inside the wire-mesh cage, but now I tend to use small baffles and multiple smaller drivers for the woofer section. See the attached picture for two examples. I find this design approach produces near constant directivity for these drivers and because there are no panels or box there are no internal or panel resonances to color the sound, etc.
I did an analysis of that in my audioXpress paper that came out last October, with numbers given for the Deltalite 2515. The aX editor moved the analysis out of the main article and into the Online Supplementary Material that you can access without a subscription. Here is how to get it:
Download this zip file:
https://audioxpress.com/files/attachment/2764
Read the file called "What Happens When Free Hanging Drivers Move?".
Reactions: wchang
