3 octaves, 400hz-3200Hz … whatcha gonna do?
Tang Band W5 2143 might do the job:
From DiBirama, crossover from 300-3,000
Probably use one of the coaxial compression drivers on a big-ish horn. I have a pair of BMS 4952 here, and the midrange section of that can cover this range comfortably, with very low distortion.
I built a prototype 18" 3-way with a Faital 18XL1800 and one of those BMS drivers per side. That was a fun pair of speakers.
Chris
Reactions: mayhem13
A Celestion Axi2050 on a K-402 horn (raw & then EQed flat):
Full transfer function of EQed single-diaphragm Axi2050/K-402 assembly:
Spectrogram of the Axi2050/K-402 assembly:
An MEH using a BMS 4592ND on a K-402 Horn, crossed at ~550 Hz and 6.3 kHz, and two Crites 1526C woofers (EQed):
Many apparently do not recognize the acoustic advantages of modern compression drivers like the Celestion Axi2050 (complex axisymmetric ring radiator Ti diaphragm) or the BMS 4592 ND (dual ring radiator polyester diaphragms) on a single straight-sided horn with tractrix or dual flare mouth rollout-like a Danley-style multiple entry horn. These exhibit full-range directivity control down to the room's Schroeder frequency (i.e., no early reflections). The size of the total assembly is about that of a Klipsch La Scala--but sounding and measuring much better in room boundary loading., They do not need to take up valuable floor space away from room walls in order to achieve full soundstage imaging performance. Tuck them in--out of the way--in typically unused room corners or against a wall and they perform even better.
Chris
