Hi!
Seems your linestage is not out of balance.
Also your test with reversing the channels shows that it is not the line stage.
Most likely a bad wiring as Cheah already suggested.
This is the big disadvantage of filament bias, if the tubes differ in emission they draw different currents. This causes a different voltage drop across the primary. In your case it means the difference between the two tubes is about 3mA which is a lot.
When using filament bias the tubes should be tested and the current should be verified in circuit since there is no self adjustment mechanism any more as in cathode bias
Best regards
Thomas
How do you calculate the 3mA, TIA for teaching me.
Ooooops...forgot...you may want to try to switch the in-put into the line amp too....to see if the problem stays with the same channel....
Hi!
So you still have the channel imbalance?
Instead of just rolling tubes, maybe try a more structured approach.
Your measurements indicated identical gain. Try at different frequencies also to make sure
When you switched the left and right inputs at the TVC, it was still the same channel which appeared louder?
Again this would indicate that the problem is not in the line stage.
Best approach:
With everything connected, measure the signals at both channels:
At linestage input
linestage output
TVC input (inside your TVC box right at the TVCs)
TVC output
That will tell you where exactly the problem occurs
It would also be helpful if you report back more clearly what you have done and where you measured to help further
best regards
Thomas
No, I fixed these when the TVCs.
Now I resoldered again & checked all input-outputs at Right channel also I'm rolling new tubes to see what's happen because the measurements are OK
Best approach:
At linestage input
linestage output
TVC output
best regards
Thomas
Ohms law
N.B. When I do the measurements I connected the probes: input direct to 100R-100K junction in place of the input RCA, output where connected to output RCA so can be a cold solder at the input RCA so I resoldered & tomorrow I will listen.
Hi!
Best approach:
At linestage input
linestage output
TVC output
best regards
Thomas
Yes I have channel imbalance.
I have the TVCs in a separate box, I used without the lineamp and NO difference of gain between channels🙂
So last measurements done without TVCs
Thanks for help
Ohms law
I guess so but how do you calculate the resistance?
Hi!
So please do the measurement steps which I listed to isolate the problem.
Report back the results exactly.
Otherwise it gets confusing
Best regards
Thomas
Best regards
Thomas
Hi!
Nothing to calculate look it up in the data sheet of the transformer. There is even a resistance mentioned in your schematic but the actual resistance is 1250 Ohms.
But don't get side tracked, you should hunt down your imbalance issue. When that is solved, you can use matching tubes
Thomas
Thomas
Here the new measurements with others tubes:
Right channel
B+ 141,6V
Heaters 1,35V
Left channel
B+ 142,3V
Heaters 1,35V
Right channel
B+ 141,6V
Heaters 1,35V
Left channel
B+ 142,3V
Heaters 1,35V
Hi!
Why don't you do the measurements as suggested instead of blindly poking around?
Thomas
I can't listen today, tomorrow morning I will listen and let us know.
Thomas
Because I guess is a cold joint & the measurements were OK except the difference of B+ that's the reason I rolled the tubes & resoldered the connections.
- Tubes / Valves
- #26 pre amp
