20k Stepped Attenuator with loudness tap?
Yes, this attenuator with thick film smt resistors is very good indeed, and only around $15.
Unfortunately they do not make these with thin film resistors because of the higher cost.
Of course, one could disassemble the control, remove the resistors in an oven, and
install the better quality parts instead, but that would be a lot of work.
The parts that are directly connected to the loudness tap, see post #7.
I'm still a bit confused. It sounds like this refers to the parts highlighted in this picture? All of them? I could place the loudness tap so the either the resistance between the input and the tap was the same as original, or so the tap to ground resistance is the same.
I would have expected C5 and R15 in the second picture in the above post to need tweaking? They go to the input of the pot, so the resistance between pin 4 and ground on that board is the resistance of the pot.
I had a h*** of a time even finding the Volume pot. Remember when that was an important part? And then it goes on a 50-mile hike both sides of the mountain (and over the multi-bus) to get to the R and C parts. I figured since I had it on my clipboard I may as well dump-back in case it helped others.
