200W BJT SFA (BJT mod from Dadod 100W CFA with Input Stage active load)
  • 200W BJT SFA.asc
Andrew, the relay will not have time to protect the transistors. This circuit uses a fast trigger protection. The relay can be used for standard DC voltage output protection. Relay contacts must be covered by feedback. It is necessary to connect a high-resistance resistor in parallel with the relay contacts in order not to break the DC feedback.
Hello de Ocampo. I showed the improvement in the diagram. 6.8 ohm resistors degrade thermal stability. Input transistors collector voltage-base equal to zero will not work normally.
I missed this thread.
I will not call it improvement, as overall feedback says transistor works with very low CE voltage. You used cascoded VAS, I tried it bat not need here where distortion is so low and it eats headroom. Different compensation, way?
