200 kHz AB amplifier
This AMP should be AB class, it has to drive an acoustic underwater antenna, with fixed amplitude, and narrow bandwith into 200 kHz (190/210 something like that). When I say pulse I don't mean a square wave, so we have to consider a sinusoidal signal, a simple case.
For DC stability I mean 0V into the output without input signal. Actually with the first schematic I posted, this DC point is instable, I don't know why.
Schemes do not open 🙁
Include a film capacitor and series resistor on the output
1-4 ohms in series with the load 🙂
Yes, but I suppose it will work only in a pure resistive 20 ohm load, so let's consider a 200 kHz sine wave input.
I attached my last Spice schematic, plase if someone can play with it to find some critical issue is welcome.
I had a more expert suggestion to be sure this topology is or is not a good choice.
