200 kHz AB amplifier
Hi guys,
I have to make a 200 kHz 10W AB amplifier with 20 ohm load.
I did a basic 3 stage SMD bipolar transistor audio AMP with Sziklai output stage and +/- 24V supply with no very success. This amp has good band but instable DC operating point, it oscillates from 0V to 0.2/0.8 and sometimes to 1V so the current switch only in a side of the two supply and it doesn't work. When the operating point is stable (very rare) the AMP works but shows a bad parasitic oscillation in the positive half. Probably this is due to the Sziklai output configuration.
I don't know why the DC point is unstable, while in simulation is few mV away from 0V.
Anyway my request is simple, with this frequency as target, should I find a new approach, a new amp configuration? Try a MOS based AMP or a completely new architecture, when can I read something about amplification at that frequency?
With a common audio AMP is not difficult extend band until 200 Khz (with some distortion but I'm not interested in) but I'm finding this DC instability so I don't know if try a new better scheme or change totally.
Without complete specifications, it is difficult to determine what you want. In class AB, at a frequency of 200 kHz, the efficiency of GNFB decreases. Crossover distortion increases. Application in the output stage of a single EF is possible. You can try the virtual battery bias diamond buffer.
????????? ????????? - ?????? Zarathustra
91307.thumb
Hi guys,
DC instability and oscillations are topology related... Maybe you could get away with some line driver ic with simple power follower stage in the loop.
What is the intended load you have to drive?
Inductive? (a coil) ,
Capacitive? (piezo), etc.
Doubt it´s a plain speaker and even if so, t those frequencies they behave very differnt than at audio frequencies.
Lots of questions.
A little background: this amp should drive an acoustic trasducer (antenna) at 200 kHz more or less. I'm not interested in THD, distortion or noise, the amp will send power in few pulse, not a clean signal. Thermal and DC stability and bandwith are important.
I can't use integrated circuit, only SMD components and TH for power end transistors, so every suggestions about IC are unusable but thanks anyway. Other schemes I've seen looks a bit complex.
Here you can see my first circuit that exibits DC instability, there are some errors but DC instability is even a mistery for me.
I'm thinking to make a PCB with a revision of that circuit, more focused, but I'm worried about DC instability will be still there, so I hope to find, with your help, the right way to get a good amp not too complex but working.
This AMP should be AB class, it has to drive an acoustic underwater antenna, with fixed amplitude, and narrow bandwith into 200 kHz (190/210 something like that). When I say pulse I don't mean a square wave, so we have to consider a sinusoidal signal, a simple case.
For DC stability I mean 0V into the output without input signal. Actually with the first schematic I posted, this DC point is instable, I don't know why.
