Hi Bamboo is Ikea Aptitlig chopping boards which are £4.99 each here in the U.K. The front is mdf with a real carbon fibre veneer the back is mdf painted black. I used some off cuts up from other projects but you should be able to make the enclosures out of 3 or 4 boards depending if you do all sides and baffles or not.
The Ikea boards are essentially just bamboo plywood it's a pretty cost effective way to make a nice enclosure without having to worry about painting. Just a wipe over with a couple of coats of tung oil followed by a wire wool bit of wax and a buff.
is the CF "veneer" self adhesive?
No I used some evostick contact adhesive
