The main digital filter for all DACs except for TDA154X is finished and has been throughly tested by several users. TDA154X version needs some polishing, but I didn't have much time to actually finish it, so it's not available at the moment. I hope to get back to it soon enough since I will have more time now.
If you wish to purchase it you can drop me a message.
Hey
I'm sorry for the delay, but I wasn't available on forum due to some other work. Anyway, I took the liberty of answering your private message 😉
I'm not sure I understand everything there, but such interpolator in "HAT" format (for raspberry and some others) would be very desirable !
(but then needs a driver)
3lite
Сan you make 32x mode with pipelined data loading ( 1\2 time load) into the DAC? So that you can use 4 chips PCM58 and get a sampling frequency of 1536 kHz.
Psychology? 😉
A typical synchronous interpolation filter like this, being LTI, doesn't create harmonic distortion. You don't see that specified on filters like this.
This "time smearing" isn't an artifact, so I really dislike using that term for it. An ideal reconstruction filter will have this "time smearing", but it will reconstruct the original waveform perfectly. It's not actually time smearing, because we don't listen to impulses.....
Some of us listen to sine waves. Some like drums with impulses, etc. I am curious what impulse-less music you listen too? Who knew?!
Would there be any way to compare this board with an AK4137EQ configured for the same type of operation?
4'33".
Unlikely. The 16 x filter raises the incoming sample rate by 16. The AK4137 converts the incoming sample rate to a specific outgoing sample rate.
I apologize, I meant more just for general 384/768 (352.8/705.6) operation and was looking for a possible comparison of the quality of the digital filter.
The signal coming out of a drum doesn't look like a Dirac impulse at all and any digital recording of it has already been low-pass filtered to prevent aliasing.
I’m lazy and don’t want to read all 10+ pages, so simple question, is this interpolation filter available for purchase? I’m cleaning up the lab and found some TDA1541A and AD1862 just begging to be used and I just can’t help myself but give in to the desire to tinker with some old tech!
Hey, yes, it is - the information along with price is available within the first post. Drop me a message if you want one, but currently I'm a bit busy, so it might take some time to assemble. That being said, keep in mind that I have created two different digital filters (a special version for TDA1540/TDA1541 only and the other one more generic for other DACs).
Fantastic work! I am in for a filter board with AD1862 PCB (already dropped a PM).
May I suggest to add a possibility to read out status information, for example to be able to show bit/fs of the input on a display and/or wire the on board LEDs to the front panel...?
- Digital Line Level
- 16x Digital interpolation filter - drive PCM56, PCM58, AD1865 and so on up to 768 kHz
