Thank you, under that power supply board there are the screws which holds the transformers, maybe there was one touching, the cracks from the power supply board sounded like static electricity discharge, i bet was a short to the ground under the board.
Greatly appreciated your help
Success
I got it working.
1. the power supply power transistor was bad and damaged some more components on the power supply board. The ebay seller send me a new power supply board minus the capacitors. Then finally I got the regulated power output voltage within the range.
2. next it was a very stupid mistake, I reversed the polarity for then inputs at the potentiometer, I think this would explain why the amplifier would briefly work when I pull out the power cord.
3. the assembly instructions which you can find on ebay item description is outdated and very poor. If you buy this amplifier ask the seller to give you the most up to date assembly instructions. They are all in Chinese but the pictures are very detailed and self explanatory.
I got it working.
I bought the same kit as the OP from ebay form the same vendor, 13W*2 6P14/EL84 Push-pull HiFi Class AB Stereo Tube Integrated Amplifier DIY KIT | eBay a while back and just getting around to building it.
Could someone possibly please email me the instructions? I lost the original instructions and the link, https://pan.baidu.com/s/1XozbSJwp7hQpwZpr6m2vTQ, no longer works. When I reached out to the seller, he requested my email address; however, ebay has a policy of not sharing personal information and blocks my reply with email address under penalty of being banned.
I would greatly appreciate it someone could email me (timmcphailster@gmail.com) the instructions or drop them in here: https://drive.google.com/drive/folders/1oCJEDGMbccMJrDlMWxMTRJmVjwiuT8iG?usp=sharing
Thanks in advance.
Thanks in advance.
Was able to get email to seller; however, they only sent schematics for the 2 main boards. Remember the assembly pdf having a lot more details, e.g- where to run cabling, mounting of transformers, which included wires and where to solder, etc. Is anybody able to share this pdf?
The OP in this thread may be able to help: https://www.diyaudio.com/community/...s-before-i-build-maybe-during-if-i-do.394962/
Appears to be the same amp kit.
jeff
jeff
Thanks. Wasn't sure how to contact the OP so was hoping a post to this thread would notify them and they could help out. Not sure why the same seller the OP used sent him the assembly pdf and only sent me the 2 schematics of the main boards. I have contacted the seller again and asked specifically for the assembly pdf and waiting to hear back from the seller. I can probably assemble from the schematics; however, there's a bunch of pre-cut wires included in the kit and not sure where they all land. Thanks for the input.
tim
tim
Sorry, just realized the link you sent was to a different thread. Will check that one out also. Thanks.
tim
tim
The format @Username will create an Alert to the indicated member. Even if you don't have private conversation permission yet.
For example: @Malcom Mal Reynolds
Suhweet! Thank you for the tip @PRR.
@Eliad, any chance you could share the assembly pdf with me please? I purchased from same vendor as yourself; however, he only sent 2 schematics for the main boards and when I asked for the DJ100 Assembeld Manual, I got no reply. The link on his ebay page no longer works,
I would greatly appreciate it you could email me (timmcphailster@gmail.com) the instructions or drop them in here: https://drive.google.com/drive/folders/1oCJEDGMbccMJrDlMWxMTRJmVjwiuT8iG?usp=sharing
Thanks,
Thanks,
@vinylkid58, thanks for pointing me to the other thread, Started reading through it and lots of great discussion on the build and just realized a poster there went thru the trouble to translate the assembly document. Sent him a request for the translated version.
Thanks for everyone's help. Next step, assemble it!
Best,
Tim
Best,
Tim
- Tubes / Valves
- 13W*2 6P14/EL84 from ebay
