12 volt power supply for tube amps
I was wondering if any one out there would have or know were to find a 12 volt power supply for maybe a SE 300b ?
I have built a pair of 300b mono blocks for home and I would really like to try to make some for the car.
Any help would be great.
Brian
Consider an old solid state 12 volt power supply designed for some of the older tube ham radio transceivers. Virtually no one runs these radios mobile any more, so a supply should be dirt cheap. Sometimes these even show up as NOS for about dirt cheap.
Drake DC-3, DC-4, Collins MP-1; there are likely many others out there.
Use it as-is, or gut it for the parts. If I were to build a mobile tube amp, this would be my starting point for power.
Win W5JAG
this is my 300b car amplifier
out put is 8 Watt + 8 watt
power supply is 12 volt to 110 volt 60 or 50 Hz
If you use output transformers and accept a hybrid approach, you don't even need a power supply. Just run the amp at 12VDC. There are plenty of tubes that can run on 12VDC and use them as voltage gain. Use mosfet followers for current gain.
Look up Susan Parker's thread on the solid state forum.
Why not just buy a regular DC-to-AC power inverter? These things are dirt cheap these days. That way you just plug a home amp into the AC power. The output is typically a distorted, noisy waveform, so you'd want to make sure you've got line filtering in between it and the amp, but you'd have to do this for any switching option anyway.
Cheap power inverters
The idea of 300B filaments jangling along with road bumps and vibration gives me the willies, but I guess you could vibration-isolate the chassis as much as possible.
