Yes; again, look at the drawing/graph from Linkwitz.So delta-f on the spreadsheet is the 3 dB down point from the peak (15dB-3= 12dB point), not the -3dB from the base of the profile?
Active Filters
Graph on the lower left.
The notch you want to synthesize is sort of the inverse of the resonance.
If you want to just test it, a pair of 9V PP3 batteries will work just fine.
So just put one on + 9V and one reversed on -9V?
Will this change anything when I use the internal 15V that the amplifier has for it's preamp that I can 'steal'
Thanks,
I took out 2 connections from the preamp out and power amp in on RCA connectors, and tried this (something my brother used in the past for his home cinema) it did a job of removing room modes automatically , but it sounds weird/unmusical/detached in the bass with this in place. Plus it makes loads of background noise in the sub. Yuk
I will use these to plug in an active filter on a overboard with RCA females feeding the circuit driven by PP3 batteries to see how this works out
DSPeaker-Anti-Mode 8033
