100W Ultimate Fidelity Amplifier
Another FH9 freshly packed and ready to serve. The sound is surprisingly good! Many thanks to Sonal Kunal for the pcb layout. The VAS transistors are KSC2690 KSA1220 because it's easier to mount fully isolated TO126. Bias is only 30mA (yes I know that it should be 100-150mA).
Hi Ivan,
very nicely built. Congratulations!
regards
Prasi
A23 !!
Hi Mr.Miles,
Just finished A23, Testing with power supply of +/- 45v ,Had bias problem and sorted out by increasing 220 ohms preset to 1k and 680 ohms to 820 ohms,,
Now able to set bias properly,,
Now I have DC offset about -0.482 V.. 😕
can you please help here....
Arasuk
Symmetrical CFA amplifiers do sound excellent but making them to perform consistently and without problems is not trivial task. There will be issues with stability, low PSRR, hum, etc. Solving these issues will require more complexity in the PSU or debuging using equipment that is not available to average builder, especially if novice or inexperienced.
Since many of the subjective advantages, if not most, are due to push pull VAS, one is tempted to combine diff input with push pull VAS, like Sansui engineers did in the late seventies (see basic Apex AX11 circuit). This is the circuit that is emulated by many industrial amps till this day (Harman Kardon, Pioneer, etc.) The question remains only how to configure input stage, to use single diff input pair (like Sansui did in it’s more economically priced models) or to use double diff input pair, like Borbely and Bongiorno, making whole amplifier fully symmetrical from input to output. It seems to me that single diff input pair has even more apealing subjective performance, probably due to less noise in the input stage where noise performance counts the most.
As far as the HEX fets are concerned, Bob Cordell in his excellent book, explicitly says that low power (50W/8R) single output pair HEX fet amp can be built without Vbe multiplier in spite of positive tempco. Having in mind low price of the HEX fets, single diff input pair VFA using symmetrical push pull VAS, appears to be the best overall compromise for simple (low transistor count) audio power amp. I was very impressed with the subjective performance of the Apex FH9 XRK mod amplifier which combines HEX fets with the basic Sansui circuit.
Keep in mind that push pull VAS is mandatory, it’s what makes audio circuits subjectively satisfying. There is an excellent highly sophisticated schematic of Sansui type amp by member DVV but I do not know if he will ever publish it here (with the component values). That amp is named Economy.
