If you ask Hugh Dean (AKSA), may be he change the design to have H2 distortion dominant or have monotonic harmonic profile.
Its AKSA virus (H2 Virus), I have contacted too.
A fatigue free, relaxing, weekend listening experience with a bit of alcohol.😀
Its 2.00 AM here. (I am listening to music as I type).
Hi, Is this layout correct?
hi klevis lovely layout 😎 . please post the pcb files of your layout.
stewin, go slow on diyaudio, build one properly and thoughtfully based on the experience of others and listen to your build, see if you like it. Then you can always build more in future.🙂
This is my simulation of FH12. Not tested.
PCB layout. Not tested.
Would be interested to build that!
Thank you for posting it. 🙂
Mr. Apexaudio I started the etching of the A23 and A33 to mr alex mm (youtube) example. Now I have 3 questions I can use 1/4 resistors and what power can I use for these boards and are there pdf files on it This forum to be able to etch this too, I can not find them
Regards Purrhula
Regards Purrhula
Selector PCB
I make copy PCB (SprintLayout 6) and added missing track to relay.
I finished build apex A9 with irf540/9540 outputs. The sound is amazing, tight bass..exceptional imaging.
What is the resistance value on bias 10k VR to obtain proper bias?
Thank you, Zinyx. Could you please post Gerbers as well?
thanks for sharing . good work😎
Regards Purrhula
You can use 1/4W resistors and PSU10 for power
Thank you. I have FH12 mod too 🙂
If I have time I will make some modification of other Apex's amplifier (in simulation). I hope Prasi will make the layout.
Hi Bimo, what about A33 cfa amp? in reducing transistors in less count? is that possible?
- 100W Ultimate Fidelity Amplifier
